+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 4
    Points: 1,628, Level: 9
    Join Date
    May 2014
    Posts
    190
    Points
    1,628
    Level
    9
    vhdl read textio with delimiters in the read file
    Hello all,
    I can read in a file using vhdl, and I can compartmentalise it based on space ' ' delimiter, however I want to be able to split the read line based on a different delimiter...primarily '|'.
    The code below will read the text file quoted below. However I want to be able to read the second quoted text file.
    Doing so will give errors about | not being and int or std_logic or whatever.
    Code VHDL - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    read_ip : process
      file file_in       : text;
      variable file_line : line;
      constant path      : string := "C:/Sandbox/REDACTED_Code/bench/SPI_S_IF_TB/";
      constant file_name : string := "rx_data_frame_1.txt";
      constant file_pwd  : string := path & file_name;
      variable scs       : integer;
      variable delimiter : string(1 to 3); -- : character;
      variable data_in   : byte;
      variable byte_index: integer;
    begin
      file_open(file_in, file_pwd, READ_MODE);
      wait until RISING_EDGE(CLK);
      -- read the header
      readline(file_in, file_line);
      while not endfile(file_in) loop
        DATA_RX_RE <= '0';
        wait until RISING_EDGE(SCLK);
        read(file_line, scs); -- int read, int if statement
        if scs = 1 then
          -- read(file_line, delimiter);
          hread(file_line, data_in);
          read(file_line, byte_index);
          DATA_RX_RE <= '1';
          SCS_RST    <= '0';
        else
          SCS_RST    <= '1';
        end if;
        DATA_RX_IN <= DATA_IN;
        wait until falling_edge(clk);
        wait until rising_edge(clk);
      end loop;
      file_close(file_in);
      report "finished" severity FAILURE;
      wait;
    end process;
    SCS |Data_in | BYTE_index | Description
    0 xx x XXX-START
    0 xx x XXX-START
    1 7E 1 START
    1 11 2 SEQ_NO*
    1 01 3 CTRL
    1 01 4 PAYLOAD
    1 00 5 PAYLOAD
    1 00 6 PAYLOAD
    1 00 7 PAYLOAD
    1 00 8 PAYLOAD
    1 AA 9 CRC32
    1 F9 10 CRC32
    1 B2 11 CRC32
    1 11 12 CRC32
    1 81 13 STOP
    0 xx x XXX-STOP
    0 xx x XXX-STOP
    0 | xx | x | XXX-START
    1 | 7E | 1 | START
    1 | 11 | 2 | SEQ_NO*
    1 | 01 | 3 | CTRL
    1 | 01 | 4 | PAYLOAD
    1 | 00 | 5 | PAYLOAD
    1 | 00 | 6 | PAYLOAD
    1 | 00 | 7 | PAYLOAD
    1 | 00 | 8 | PAYLOAD
    1 | AA | 9 | CRC32
    1 | F9 | 10 | CRC32
    1 | B2 | 11 | CRC32
    1 | 11 | 12 | CRC32
    1 | 81 | 13 | STOP
    0 | xx | x | XXX-STOP
    •   Alt20th April 2017, 07:35
      advertising
  2. #2
    Advanced Member level 5
    Points: 35,259, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,455
    Points
    35,259
    Level
    45
    Re: vhdl read textio with delimiters in the read file
    VHDL does not contain any standard code to do this - if you need to break up a string based on other delimeters, you need to parse the string yourself manually.
    If you're happy to use protected types (you need to use VHDL 2002 or later) then your problem is something I came up against a long time ago, and wrote this:
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    60
    61
    62
    63
    64
    65
    66
    67
    68
    69
    70
    71
    72
    73
    74
    75
    76
    77
    78
    79
    80
    81
    82
    83
    84
    85
    86
    87
    88
    89
    90
    91
    92
    93
    94
    95
    96
    97
    98
    99
    100
    101
    102
    103
    104
    105
    106
    107
    108
    109
    110
    111
    112
    113
    114
    115
    116
    117
    118
    119
    120
    121
    122
    123
    124
    125
    126
    127
    128
    129
    130
    131
    132
    133
    134
    135
    136
    137
    138
    139
    140
    141
    142
    143
    144
    145
    146
    147
    148
    149
    150
    151
    152
    153
    154
    155
    156
    157
    158
    159
    160
    161
    162
    163
    164
    165
    166
    167
    168
    169
    170
    171
    172
    173
    174
    175
    176
    177
    178
    179
    180
    181
    182
    183
    184
    185
    186
    187
    188
    189
    190
    191
    192
    193
    194
    195
    196
    197
    198
    199
    200
    201
    202
    203
    204
    205
    206
    207
    208
    209
    210
    211
    212
    213
    214
    215
    216
    217
    218
    219
    220
    221
    222
    223
    224
    225
    226
    227
    228
    229
    230
    231
    232
    233
    234
    235
    236
    237
    238
    239
    240
    241
    242
    243
    244
    245
    246
    247
    248
    249
    250
    251
    252
    253
    254
    255
    256
    257
    258
    259
    260
    261
    262
    263
    264
    265
    266
    267
    268
    269
    270
    271
    272
    273
    274
    275
    276
    277
    278
    279
    280
    281
    282
    283
    284
    285
    286
    287
    288
    289
    290
    291
    292
    293
    294
    295
    296
    297
    298
    299
    300
    301
    302
    303
    304
    305
    306
    307
    308
    309
    310
    311
    312
    313
    314
    315
    316
    317
    318
    319
    320
    321
    322
    323
    324
    325
    326
    327
    328
    329
    330
    331
    332
    333
    334
    335
    336
    337
    338
    339
    340
    341
    342
    343
    344
    345
    346
    347
    348
    349
    350
    351
    352
    353
    354
    355
    356
    357
    358
    359
    360
    361
    362
    363
    364
    365
    366
    367
    368
    369
    370
    371
    372
    373
    374
    375
    376
    377
    378
    379
    380
    381
    382
    383
    384
    385
    386
    387
    388
    389
    390
    391
    392
    393
    394
    395
    396
    397
    398
    399
    400
    401
    402
        -- This protected type handles the tokenisation of strings. Treat it as an object instantiation.
        -- This protected type takes in a string an breaks it into separate strings using the given
        -- delimiter, or it reaches the end of the string, at which point it will return a null string.
        -- Below is an example of it's use showing all containing functions
        -- eg.
        -- variable st     : string_tokeniser_t;
        -- variable my_str : line;               --Line should be used because you dont know the string
        --                                       --length until it is returned
        -- st.setstring("Hello|World");
        -- st.set_delim("|");
        -- echo(st.get_next_token)  --puts "Hello" onto console
        -- echo(st.get_next_token)  --puts "World" onto console
        -- st.restart;
        -- for i in 1 to st.count_tokens('|') loop
        --   echo(st.get_next_token);  -- puts "Hello" on colsole   when i = 1,
        --                                               -- "World" when i = 2
        -- end loop;
        -- st.cleanup   --to ensure all pointers  are deleted
        -- Common Parameters
        -- delim    : The character(s) to use as string delimiters.
        -- S        : The string to be tokenised
        -- rtn_null : If true, delimiters are absolute. ie. 2 adjacent delimiters would mean return a
        --            a string of 0 length.
        --            When false, if the return string length is 0, keep trying until a non-null string
        --            is found. (default to false)
        type string_tokeniser_t is protected
            --Set the string that needs tokenising
            procedure set_string(s : string);
            --set the delimiter to use during tokenising and counting tokens
            -- if a string is set, all characters in the string are considered delimeters
            procedure set_delim(delim     : character);
            procedure set_delim(delim     : string);
            procedure set_delim_whitespace;
            -- With this set false, two adjacent delimeters will cause a null token to be returned
            -- Set true, all delimeters are skipped between tokens (unless end of string is reached)
            procedure set_return_null_tokens(rtn_null : boolean);
            -- When set true, the delimeter is also returned (default false)
            procedure set_return_delim( rtn : boolean );
            --restart the tokenising process with the previously entered string
            procedure restart;
            --DEALLOCATE all pointers (may help prevent memory leaks)
            procedure cleanup;
            --Get the next token from the string specified
            --If no delimiter specified, the last used delimiter will be used
            impure function get_next_token(delim    : character;
                                           rtn_null : boolean := false) return string;
            impure function get_next_token(delim    : string;
            impure function get_next_token                              return string;
            -- Same as the get_next_token functions, but return nothing
            -- used as a means to take tokens off the string
            procedure bin_next_token(delim    : character;
                                     rtn_null : boolean := false);
            procedure bin_next_token(delim    : string;
            procedure bin_next_token;
            --The number of tokens remaining in the current string
            impure function count_tokens(delim    : character;
                                         rtn_null : boolean := false) return natural;
            impure function count_tokens(delim    : string;
            impure function count_tokens                              return natural;
        end protected string_tokeniser_t;
    type string_tokeniser_t is protected body
            variable tok_str        : line;
            variable next_tok_idx   : natural;
            variable d              : line;
            variable rtn_n          : boolean := false;
            variable r_delim        : boolean := false;
            --Set procedures for setting internal variables
            procedure set_string( s : string) is
            begin
                --clean up existing instance
                DEALLOCATE(tok_str);
                --Open a new memory area and put the data into it
                tok_str                 := new string(s'range);
                tok_str.all             := s;
                next_tok_idx            := tok_str.all'low; --starting point of the string
            end procedure;
            procedure set_delim(delim : character) is
            begin
                DEALLOCATE(d);
                d   := new string'(delim & "");
            end procedure set_delim;
            procedure set_delim(delim : string) is
            begin
                DEALLOCATE(d);
                d   := new string'(delim);
            procedure set_delim_whitespace is
            begin
                DEALLOCATE(d);
                d := new string'(" " & HT & LF & VT & FF & CR );
            end procedure set_delim_whitespace;
            procedure set_return_null_tokens(rtn_null : boolean) is
            begin
                rtn_n   := rtn_null;
            end procedure set_return_null_tokens;
            procedure set_return_delim(rtn : boolean) is
            begin
                r_delim   := rtn;
            end procedure set_return_delim;
            --Restart tokenising from the start of the string
            procedure restart is
            begin
            end procedure restart;
            procedure cleanup is
            begin
                DEALLOCATE(d);
            end procedure cleanup;
            -- match the character c to any of the chars in the delim string
            impure function match_delim( c : character) return boolean is
            begin
                for i in d.all'range loop
                    if c = d.all(i) then return true;
                    end if;
                end loop;
                return false;
            end function match_delim;
            --Get the next token from the string bounded by the delimeter
            impure function get_next_token return string is
                variable temp           : natural;
            begin
                if tok_str = null then
                    report "string_tokeniser-get_next_token: Null pointer found - returning null string"
                        severity WARNING;
                    return "";
                elsif next_tok_idx > tok_str.all'high then --Previously ended a string
                    --no need to report. String exists, but all tokens returned
                    return "";
                else
                    --User wants to search the previous specified string
                    search_loop_old : for i in next_tok_idx to tok_str.all'high loop
                        if match_delim(tok_str.all(i)) then --found delimiter match
                            temp                := next_tok_idx;
                            next_tok_idx        := i + 1; --this is where the next search should start
                            -- 0 length between delims
                            if next_tok_idx - temp = 1 then
                                -- user wants a null string
                                if rtn_n then
                                    if r_delim then
                                        return tok_str.all(next_tok_idx-1 to next_tok_idx-1);
                                    else
                                        return "";
                                    end if;
                                end if;
                            else
                                if r_delim then
                                    return tok_str.all(temp to i);
                                else
                                    return tok_str.all(temp to i-1);
                                end if;
                            end if;
                            -- If rtn_n = false this should keep looping until it's found a new
                            -- retrunable token, stripping out delimeters
                        end if;
                    end loop search_loop_old;
                    --run off the end of the string, so return from the last know start index to the end
                    next_tok_idx        := tok_str.all'high + 1; --This is off the end so subsequent
                                                            --calls return null
                    return tok_str.all(temp to tok_str.all'high);
                end if;
            end function get_next_token;
                                           rtn_null : boolean := false) return string is
            begin
                DEALLOCATE(d);
                rtn_n   := rtn_null;
                return get_next_token;
            begin
                DEALLOCATE(d);
                rtn_n   := rtn_null;
            --Do the same as the function above, but return nothing.
            procedure bin_next_token is
            begin
                    report "string_tokeniser-get_next_token: Null pointer found (No string set for tokenising)"
                        severity WARNING;
                    null;
                else
                                -- user interested in 0 length strings
                                if rtn_n then
                                    return;
                                end if;
                            else
                                return;
                            end if;
                        end if;
                                                            --calls return null
                end if;
            end procedure bin_next_token;
                                     rtn_null : boolean := false) is
            begin
                DEALLOCATE(d);
                rtn_n   := rtn_null;
                bin_next_token;
            begin
                DEALLOCATE(d);
                rtn_n   := rtn_null;
                bin_next_token;
            --count the number of tokens left in the string bounded by the delimiter
            impure function count_tokens return natural is
                variable n_tok          : natural := 0;
                variable prev_delim_i   : natural;
            begin
                n_tok   := 0;
                    report "string_tokeniser-count_tokens: Null pointer detected, no string available to count."
                        severity WARNING;
                else
                    --count the number of tokens left in the current stored string
                        if     match_delim(tok_str.all(i))          --found a match
                            or i = tok_str.all'high                 --end of the string
                        then
                            if i = prev_delim_i + 1 then    -- null token found
                                if rtn_n then
                                    n_tok   := n_tok + 1;
                                end if;
                            else
                                n_tok   := n_tok + 1;
                            end if;
                            prev_delim_i := i;   -- store the index of this delimeter
                        end if;
                    end loop;
                end if;
                return n_tok;
            end function count_tokens;
                                         rtn_null : boolean := false) return natural is
            begin
                DEALLOCATE(d);
                rtn_n   := rtn_null;
                return count_tokens;
            begin
                DEALLOCATE(d);
                rtn_n   := rtn_null;
        end protected body string_tokeniser_t;
    1 members found this post helpful.
