Arduino Error 'keypadEvent' was not declared in this scope
dann11
Full Member level 3
Hi! I am trying to use the keypad.addEventListener() to call an event I did use it with keypadEvent,and then compiling my code gives me an Error 'keypadEvent' was not declared in this scope. Can you please help me where might have I gone wrong.
#include <Keypad.h>
//pin assignments
int latchPin = 15;
int clockPin = 14;
int dataPin = 16;
int keySwitch = 9;
int ledActual = 17;
int ledTarget = 18;
int ledTactTime = 19;
//global variables
byte digitBuffer[6] = {0};
int digitScan = 1;
byte valueKeypad = 0;
byte num = 0;
//keypad
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'#','0','*','D'},
byte rowPins[ROWS] = {0 , 1, 2, 3}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {4, 5, 6, 7};//nnect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS );
//display 0,1,2,3,4,5,6,7,8,9:
byte datArray[10] = {B01111101, B00100001, B01010111, B01110011, B00101011, B01111010, B01111110, B01100001, B01111111, B01111011};
void setup()
 //Serial.begin(9600);
  //pin designation
  pinMode(latchPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(dataPin, OUTPUT);
  pinMode(keySwitch, INPUT);
  pinMode(ledActual, OUTPUT);
  pinMode(ledTarget, OUTPUT);
  pinMode(ledTactTime, OUTPUT);
  //initialize display
  digitalWrite(latchPin, LOW);
  shiftOut(dataPin,clockPin, MSBFIRST, datArray[0]);
  digitalWrite(latchPin, HIGH); //pull the latchPin to save the data
  keypad.addEventListener(keypadEvent);
void keypadEvent(KeypadEvent key)
  if (keySwitch == LOW)
  switch(keypad.getState())
    case PRESSED:
        switch(key);
              case 'A':
                   digitalWrite(ledActual, HIGH);
                   //transmit data to the display - Actual Value
              break;
              case '3':
                   digitalWrite(ledTarget, HIGH);
                   //transmit data to the display - Target Value
              break;
              case '2':
                   digitalWrite(ledTactTime, HIGH);
                   //transmit data to the display - Time Value
              break;
              case '1';
                    digitalWrite(ledActual, LOW);
                    digitalWrite(ledTarget, LOW);
                    digitalWrite(ledTactTime, LOW);
                   //save the Actual Value to the Actual Variable
              break;
    break;
    case RELEASED:
        switch(key);
              case 'A':
                   keypadAction();
              break;
              case '3':
                   keypadAction();
              break;
              case '2':
                   keypadAction();
              break;
              case '1';
              break;
    break;
    case HOLD:
        switch(key);
              case 'A':
              break;
              case '3':
              break;
              case '2':
              break;
              case '1';
              break;
    break;
add
void loop()
//the keypad case statements here...
to your code module.
What happens when you write
as
within the void loop()
and remove it from setup()
    V
I have made it worked. It just re-arranged each function. Thanks for the help anyway.
Arduino "no_Key" can it be used in multiple function
Hi! I am trying to used the "no_key" of arduino keypad with multiple function, as the first function is called, it works perfectly, but when the next function(also uses the "no_key") is called keypad is no longer responding. Can the "no_key" be used in multiple function?
first function:
void keypadPress()
  char key = keypad.getKey();
  if(keypadActionFlag == true)
      if(key != NO_KEY)
            if (key == 'A')
                  keypadActualFlag = true;
           else if (key == '3')
                keypadTargetFlag = true;
          else if (key == '2')
                keypadTactTimeFlag = true;
         else if (key == '1')
                keypadActualFlag = false;
                keypadTargetFlag = false;
                keypadTactTimeFlag = false;
          else
                  //do nothing
   else
    //do nothing
2nd function:
void keypadAction()
if ((keypadActualFlag == true) || (keypadTargetFlag == true) || (keypadTactTimeFlag == true))
  char keyPad = keypad.getKey();
  //keypad printing of value
  if (keyPad != NO_KEY)
       if (keyPad == 'D')
              //delay(300);
              num = datArray[1];
              // Serial.println(num);
              Serial.println("Keypress");
        else if (keyPad == 'C')
              // delay(300);
              num = datArray[2];
        else if (keyPad == 'B')
              //  delay(300);
              num = datArray[3];
        else if (keyPad == '*')
              num = datArray[4];
              // delay(300);
        else if (keyPad == '9')
               //delay(300);
               num = datArray[5];
         else if (keyPad == '6')
              // delay(300);
              //  delay(200);
              num = datArray[6];
         else if (keyPad == '0')
              num = datArray[7];
         else if (keyPad == '8')
              num = datArray[8];
         else if (keyPad == '5')
              num = datArray[9];
        else if (keyPad == '7')
              // delay(300);
              num = datArray[0];
         else if (keyPad == '4')
              digitScan = 0;
              //delay(250); //wait for a second
        else if (keyPad == '#')
              digitScan = 0;
         else
          //do nothing
    digitBuffer = num;
    displayValue();
 /* else
    Serial.println("keypadPress else");
else
  // do nothing
