Results 1 to 7 of 7
    Points: 358, Level: 4
    Feb 2016
    32
    358
    Priority encoder for one-hot-to-binary
    I am trying to understand how using 'or' avoids synthesizing priority encoder with the following circuit diagrams generated by yosys, Why would we have 31:2 bits of $10_Y mapped back to itself ? The verilog source code could be found below or https://www.edaplayground.com/x/4H6a
    With OR
    Without OR
    Code Verilog - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    // Convert a one-hot signal to a binary index corresponding to the active bit.
    // (Binary encoder)
    // If DIRECTION is "LSB0", index 0 corresponds to the least significant bit
    // If "MSB0", index 0 corresponds to the most significant bit
    `timescale 1ns/100ps
    module oh_to_idx
        #(parameter NUM_SIGNALS = 4,
        parameter DIRECTION = "LSB0",
        parameter INDEX_WIDTH = $clog2(NUM_SIGNALS))
        (input[NUM_SIGNALS - 1:0]         one_hot,
        output reg [INDEX_WIDTH - 1:0]   index);
        integer oh_index;
        always @(*)
        begin : convert
            index = 0;
            for (oh_index = 0; oh_index < NUM_SIGNALS; oh_index=oh_index+1)
            begin
                if (one_hot[oh_index])
                begin
                    if (DIRECTION == "LSB0")
                        index = index | oh_index[INDEX_WIDTH - 1:0];    // Use 'or' to avoid synthesizing priority encoder
                    else
                        index = index | ~oh_index[INDEX_WIDTH - 1:0];
                end
            end
        end
    endmodule
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    module oh_to_idx_tb;
        reg[3:0] one_hot;
        wire[1:0] index;
        oh_to_idx A1
            .one_hot(one_hot),
            .index(index)
        initial
        begin
            $dumpfile("oh_to_idx.vcd");
            $dumpvars(0, oh_to_idx_tb);
            one_hot = 4'b1000;
            #5 one_hot = 4'b0100;
            #5 one_hot = 4'b0010;
            #5 one_hot = 4'b0001;
            #20 $finish;
        end
    endmodule
    What are actual purposes of the $or labelled $10 and $12 ?
    •   Alt19th April 2017, 02:59
      advertising
    Points: 227,400, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,184
    227,400
    100
    Re: Priority encoder for one-hot-to-binary
    Your question is missing a clear specification of the intended decode function. Why do you want to avoid a priority encoder? Do you understand the implications?
    Obviously the priority encoder is requiring more logic cells.
    •   Alt19th April 2017, 07:48
      advertising
    Feb 2016
    32
    358
    The following circuit diagram is generated from Altera Quartus synthesis tool:
    Is it correct to identify the extra multiplexer generated as a form of priority encoder for index[0] ?
Name:	Screenshot from 2017-04-19 22-19-58.png
    •   Alt19th April 2017, 15:22
      advertising
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,184
    227,400
    100
    You'll find the answer when you list the output for all possible codings of the one_hot input, not only the legal combinations.
    Feb 2016
    32
    358
    The easiest way is to think about what would happen if there was more than one bit set (even though we avoid that in this design, the synthesis tool needs to account for all logic states). If I had implemented it like this:
    8
    9
    10
    11
    begin
        begin
               index = oh_index[INDEX_WIDTH - 1:0];
            else
                index = ~oh_index[INDEX_WIDTH - 1:0];
            end
        end
    end
    It would have to encode a binary signal that corresponds to the lowest bit set to be correct. The only way to do that is with a priority encoder (which has a lot of latency). If multiple bits were set with the implementation where there is an OR gate, the outputted index would be the logical OR of indices of set bits, which is meaningless. But I don't care about that case anyway.
    The above quoted message is email reply snippet from the code author.
    What do you guys understand by "The only way to do that is with a priority encoder (which has a lot of latency)" ?
    •   Alt21st April 2017, 02:38
      advertising
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,184
    227,400
    100
    A circuit that outputs either the index of the leftmost or rightmost activated bit is a priority encoder. Saying it has "at lot of latency" is an overstatement, I think. Logic is bit more complex and latency respectively higher.
    As previously mentioned
  7. #7
    Feb 2016
    32
    358
    From what I understood, the code from https://github.com/jbush001/NyuziPro..._to_idx.sv#L40 is intended to modify the priority encoder to be a simple encoder where each bit could be checked independently.
    What I do not understand is why we specifically use "OR" operator on 'index' for such intention ?
