+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 3
    Points: 323, Level: 3
    Join Date
    Jul 2016
    India
    Posts
    25
    Points
    323
    Level
    Difference between sampling rate and conversion time
    Hi All,
    I am confused with sampling rate and conversion time. What is the difference between them in data acquisition system?
    Could anybody please give me hint on this.
    Regards,
    Viyaaloth
    •   Alt17th April 2017, 09:25
      advertising
  2. #2
    Member level 2
    Points: 462, Level: 4
    Join Date
    May 2016
    Posts
    45
    Points
    462
    Level
    Re: Difference between sampling rate and conversion time
    Conversion time is the time it takes for ADC to convert analog input to digital output. Sampling rate is how many times the signal is sampled each second.
    1 members found this post helpful.
    •   Alt17th April 2017, 10:39
      advertising
  3. #3
    Newbie level 2
    Points: 133, Level: 1
    Join Date
    Apr 2017
    Posts
    Points
    133
    Level
    Adding more to the answer of @Palpurul, Normally the conversion time should be less than the time between the two samples are taken. For example, if your sampling rate is 50 Hz, i.e signal is sampled at every 20 ms, the conversion time should be less than 20 ms. If not, you may loose the next sample as your are still converting the previous sample value.
    •   Alt17th April 2017, 14:42
      advertising
  4. #4
    Advanced Member level 5
    Points: 34,950, Level: 45
    Join Date
    Mar 2008
    USA
    Posts
    5,592
    Points
    34,950
    Level
    45
    This depends on the converter architecture. Pipelines
    can have sample rate > conversion time, because you
    are marching multiple samples down the pipe. A SAR type
    could go almost to conversion=sample (plus setup/hold
    and maybe S/H settling time).
