+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Member level 1
    Points: 1,744, Level: 9
    Achievements:
    7 years registered
    Join Date
    Jul 2009
    Posts
    41
    Points
    1,744
    Level
    9
    spartan6 enable input signal remains latched
    Hello all,
    i started out a uart tx module for sending a packet of 4bytes ( one at a time).... the data is sent ok, but i am facing some strange behaviour
    My problem is on the enable signal, i hooked the enable of the uart module to a button on my board, also connected a LED in the logic to have a "visible feel"
    If i press the button once, i expect some uart action, but if i release the button the uart should be stoped... but its not....
    the LED is lighted and with a logic analyzer i have continous data when the button is not pressed !!
    Its like the enable input remains latched in Hi state... and i wonder why? Is there a problem in my code? i did some simulation in ISE but there everything is working as expected
    I highlighted the problem in my code bellow
    here is my top module
    module main_module(
    output uart_out , // uart  tx line
    input  clk,
    input button,
    output LD2
    parameter [31:0] testing = 32'h 44332211;
    // instatiate the uart module
    uart4byte uuu(
      .uart_clock(clk),
      .data(testing),
      .enable(button),
      .tx_out(uart_out),
      .led(LD2)  // output to led
    endmodule;
    and my 32bit uart module
    module uart4byte(
    input uart_clock,
    input [31:0] data,
    input enable,
    output reg tx_out,
    output reg led
    	parameter idle  = 3'b000; // 0
    	parameter start = 3'b001; // 1
    	parameter stop  = 3'b010; // 2
    	parameter send  = 3'b011; // 3
    	parameter clear = 3'b100; // 4
            reg [7:0] pos = 0;
    	reg [7:0] ii = 0;
    	reg [7:0] state      =0; // set initial 3bit register to 0value ( binary 000) ( idle)
    	reg [7:0] index      =0; // bit index
    	initial begin
    	   tx_out = 1;
    	end
    	always @(posedge uart_clock) begin
    			 case (state)
    	          idle:
    	              begin
    			     tx_out    <=1'b1; // in idle the dataline is set to high
                                 index     <=0; // reset bit index
       						  if(enable == 1) begin
    		   				     	state <= start; // set  state for start(1)
    							led<=1;
    						   end
    						   else begin
    						           state <=idle;
    							   led<=0;
       					           end
    		           end
        start: // 1
    	     begin
    		          tx_out <=1'b0; // set dataline to low, this indicates start bit in uart communication
    			 state <= send; // set next state for sending the 8bit data
    	     end
       send: //3
    	    begin
    		 tx_out <= data[index+pos];
                                        if(index < 7) begin // check to see if we sent all 8 data bits
    					  index <= index +1;//increment by 1
    					  state <= send; // set next state for sending remaining bits
    			             end
    				      else begin // if we sent all the data bits do this...
    					   index <=0 ; // clear the index counter
    					    state <= stop; // set next state for sending the stop bit
    				     end
                 end
         stop:
    	    begin
    		           tx_out<=1'b1; // set the dataline to high, indicating a stop bit
    			   state <= clear; // set next state for clearing the data line
    	    end
          clear:
    	    begin
    						 if((index+pos)== 31) begin
    						  	pos<=0;
    							state <= idle; // set next state for clearing the data line
    					          end
    				                  else begin
    						     state<=start; // back to start
    						     pos <=pos + 8; // increment by 8positions
    				                 end
    		end
         default:
    	  state <= idle;
    	  endcase
    end
    endmodule
    •   Alt16th April 2017, 18:55
      advertising
  2. #2
    Super Moderator
    Points: 55,084, Level: 57
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,140
    Points
    55,084
    Level
    57
    Re: spartan6 enable input signal remains latched
    Show the schematic of button, Led, logic analyzer...how they are connected to the FPGA.
    Did you take care about (unused) inputs: Don't let them floating.
    Klaus
    •   Alt16th April 2017, 19:18
      advertising
  3. #3
    Member level 1
    Achievements:
    7 years registered
    Join Date
    Jul 2009
    Posts
    41
    Points
    1,744
    Level
    9
    Hello Klaus,
    the logic analyzer (salaee 16channel) is connected between ground and pin P7
    i am using a small board from digilent cmod s6, i have atached the schematic, in the mean time bellow is my constrains file
    NET "button" LOC="P9" | IOSTANDARD=LVCMOS33 ; // button 1
    NET "uart_out" LOC="P7" | IOSTANDARD=LVCMOS33 ; // board pin4
    NET "LD2" LOC="N4" | IOSTANDARD=LVCMOS33 ; // LED2
    NET "clk" LOC="N8" | IOSTANDARD=LVCMOS33 ; //
    NET "clk" TNM_NET = clk;
    TIMESPEC TS_clk = PERIOD "clk" 125 ns HIGH 50%;
    In the schematic, i am ussing button 1 which is connected to pin P9 of the fpga chip, i see it has a permanent pull down resistor so... i am guessing this is not floating at all.
    the LED2 which i am using has a ground permanent connection, so from the fpga side a HIGH level is required
    what is strange i used a simple code just to see if the button really works.... So in my top module i removed the instance of uart4byte moule, and left only the code bellow just to see whats happening
    instead of output LD2, i used output reg LD2 so i can assign a value....
    always @(posedge clk) begin
    if(button == 1) begin
    LD2 <=1;
    end
    else begin
    LD2 <=0;
    end
    so this simple code above is working.... i am beggining to run out of ideeas
    Hello,
    i came across this strange solution, its seems index<=0 was causing some trouble..
    i kept getting some warning mesages from ISE 14.7
    Due to other FF/Latch trimming, FF/Latch <index_1> has a constant value of 0 in block <uart4byte>. This FF/Latch will be trimmed during the optimization process.
    					          		  index <= index +1'd1;//increment by 1
    					               end
    							    end
    							 end
    So i remove that instance of index and moved it bellow in the code, and there is no more warning, and the hardware works !
    						  	pos<=8'd0;
    						  end
    				       else begin
    						   pos <=pos + 8'd8; // increment by 8positions
                                                       index<=0;
    				       end
    Since i am not a experienced guy in HDL programing, why is this diference since from the logical point of view both should do the same thing?
    •   Alt16th April 2017, 21:31
      advertising
  4. #4
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    Join Date
    Apr 2014
    Posts
    11,140
    Points
    55,084
    Level
    57
    No schematic for switch connection.
    Klaus
  5. #5
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    The problem in your code was a logic issue.
        send: //3
          begin
          end else begin // if we sent all the data bits do this...
            index <=0 ; // clear the index counterYou clear this when exiting the state and the index was 7, but now becomes 0
          end
          end
        clear:
          begin
          tx_out<=1'b1; // set the dataline to high, indicating a stop bit Not sure about this I thought your intention was to clear the tx_out in this state?
          if((index+pos)== 31) begin // index+pos can never be equal to 31 as index is always 0 from the above exit condition. Iff you had instead made this comparison pos == 24 it would have worked correctly
            pos<=0;
          end else begin
          end
  6. #6
    Member level 1
    Achievements:
    7 years registered
    Join Date
    Jul 2009
    Posts
    41
    Points
    1,744
    Level
    9
    Hello adsee, thanks for you remark...
    I still have a question since i am new in verilog regarding always blocks... i still have trouble in code exectuions...
    If i want to use "enable" signal in if else inside a always block, its mandatory that "enable" should be present in the sensitivity list of the always block? like this
    always @(posedge clock or enable)
    Variant 1
    input enable,
    output reg [31:0] count
    always @(posedge clock) begin
          count <= count + 32'd1;
       end
       else begin
          count<=0;
       end
    end
    or
    Variant2
    input enable,
    always @(posedge clock or enable) begin
       end
       else begin
          count<=0;
       end
    end
    which is the corect code variant?
    Thanks
    •   Alt18th April 2017, 00:01
      advertising
  7. #7
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    The first code sample implements a synchronous enable.
    The second implements an asynchronous enable (it may or may not synthesize correctly, I haven't checked).
    Besides the posedge clock, the only other signal you can or should include is an asynchronous reset either posedge reset (for an active high reset) or negedge reset (for an active low reset).
    For combonational logic use always @ (*) or always @* to avoid missing something in the sensitivity list.
    You should always stay aware of the fact you are describing hardware and FFs only update on clock edges or when asynchronous inputs like Reset and Set pins are active. Other inputs like Data and Enable are synchronous.
