Results 1 to 19 of 19
    Junior Member level 3
    Points: 157, Level: 2
    Feb 2017
    27
    157
    Isolated probe for inverter measurements needed?
    HI ,
    i have DSO TBS2072b from tektronics (ground is not isolated )
    will the DSO will get damage if i check mosfet oputput without using isolated probe (using normal probe).??
    Actually i am buying this oscilloscope so during demo the marketing team told me about this so i am confused coz i never herd of such things before . Or is it just just there marketing trick to sell me an isolated probe as well?
    Last edited by FvM; 15th April 2017 at 09:42. Reason: New topic, moved to new thread
    Points: 227,606, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,227
    227,606
    100
    Re: Isolated probe for inverter measurements needed?
    Mains supplied oscilloscopes like TBS2072 have the ground tied to protective earth. Respectively you must not connect the probe ground to a mains supplied inverter without isolation transformer.
    High voltage differential probes are a standard tool of power electronics development. You can get less expensive types from third parties.
    Feb 2017
    27
    157
    what is this isolation transformer??
    can u please explain with the help of a diagram on how to use isolation tranformer while testing mosfert output with normal probe.
    thanks in advance for your help
    •   Alt15th April 2017, 11:40
      advertising
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,227
    227,606
    100
    Isolation transformer isolates the 230V inverter power supply.
    Points: 786, Level: 6
    Altaero's Avatar
    Dec 2013
    St-Petersburg, Russia
    33
    786
    If your circuit is battery-powered so no problems at all, you can measure freely. If your circuit uses isolated power supply (i.e. power adapter with 2 pins for mains and a trasformer inside), again no restrictions. But if your power supply connects 0V rail (GND) to protective earth (PE), you can connect alligator clips of the probe ONLY to 0V rail in your circuit. But you're still able to check your circuit (mosfet) and can measure voltage relative to 0V rail. If in this case you try to connect the alligator clip to a point that has a potential other than 0V, you'll make low-resistance path with non-zero voltage that may lead to disasterous results because of large current.
    •   Alt15th April 2017, 19:58
      advertising
    Points: 11,470, Level: 25
    schmitt trigger's Avatar
    Apr 2013
    C4E4DEEEDCE6ECD2
    1,938
    11,470
    25
    At work, we use some very expensive LeCroy diff probes.
    At my home lab, I use the much less expensive ProbeMaster 4232
    They have many models, depending on your budget and your requirements.
    http://probemaster.com/differential-probes/
    My batteries are recharged by "Helpful Post" ratings.
  7. #7
    Member level 3
    Points: 1,601, Level: 9
    Mar 2010
    Bangalore
    61
    1,601
    9
    You can use a 220V/220V isolation transformer with 100W power. You may get this from any small term transformer manufacturer.
    •   Alt17th April 2017, 05:20
      advertising
  8. #8
    Feb 2017
    27
    157
    if i use 220/220v isolation transformer with 100W power. the connections will be like ine side of transformer will be connected to probe + and gnd . and the other side will serve as testing points . Then no need to worry about connections gets accidently reversed ?? I hope this is what u ment .
    Image is attached as per my understanding
    http://obrazki.elektroda.pl/2401855700_1492407904.jpg
  9. #9
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,227
    227,606
    100
    The schematic seems to connect the isolation transformer between the device under test and the oscilloscope probe. This won't work for the intended purpose and will in case of doubt damage the device under test.
    The suggestion was to isolate the inverter power supply.
    There's also a theoretical option to isolate the oscilloscope supply, but it involves a hazardous contact voltage at the oscilloscope case and controls and thus can't be suggested.
  10. #10
    Feb 2017
    27
    157
    then how am i suppose to use isolation transformer please help me . it would be great if u prove me with a pictorial example.
  11. #11
    Apr 2013
    C4E4DEEEDCE6ECD2
    1,938
    11,470
    25
    An isolation transformer has a plug, which you connect to the wall outlet; and a connector which you connect to the device under test.
    Check for instance: http://www.ebay.com/itm/STANCOR-ISOL...wAAOSww3tY7qk0
    NOTE: I'm not promoting this product or vendor. I only used it as an example, because it has good images.
  12. #12
    Feb 2017
    27
    157
    Quote Originally Posted by schmitt trigger View Post
    but i did not understand how to use this while testing an inverter circuit if possible can you please elaborate using an image
  13. #13
    Apr 2013
    C4E4DEEEDCE6ECD2
    1,938
    11,470
    25
    Very simple:
    Instead of connecting the inverter directly to your wall outlet, connect it first to the isolation transformer.
    Then connect the isolation transformer to the wall outlet.
    In plain English, the isolation transformer will be between the wall outlet and the device you are testing.
  14. #14
    Feb 2017
    27
    157
    but inverter im testing will be powered by the battery
  15. #15
    Apr 2013
    C4E4DEEEDCE6ECD2
    1,938
    11,470
    25
    Quote Originally Posted by Akshaydpal View Post
    You should have started by telling us this in the first place.
    If the inverter is ONLY powered from the battery, and NOT CONNECTED IN ANY WAY to the AC mains or physical GROUND, then it is effectively floating.
    You don't require an isolation transformer.
  16. #16
    Feb 2017
    27
    157
    so that means while testing mosfet i dont need diffrential probe either
  17. #17
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    39,227
    227,606
    100
    It depends. Grounding a circuit node through the probe ground clip can affect circuit operation in different ways, even if it's isolated. If you e.g. ground a bridge output node to measure high side transistor Vgs or Vds, you superimpose a high frequent common AC voltage to the complete inverter which may cause all kind of problems.
    •   Alt22nd April 2017, 09:18
      advertising
  18. #18
    Apr 2013
    C4E4DEEEDCE6ECD2
    1,938
    11,470
    25
    You can safely measure low side mosfets.
    As FvM has explained, a high side mosfet, may cause erratic behavior.
  19. #19
    Feb 2017
    27
    157
    http://obrazki.elektroda.pl/8203938900_1493439663.jpg
    this is my current inverter testing set up probe is normal probe
    in this case do i need any isolation transformer to keep my dso safe . if i need sonthing please guide me how to keep my dso safe im using tbs2072
