spyromike
Newbie level 2
Hello,
I am importing a German oil-hydraulic embossing machine (35 tons) for the production of novelty license plates that runs on a regular german household outlet / power of 230V/50Hz.
In order to run the machine here in the U.S. the manufacturer says that in addition to stepping up the voltage from 110 to 230, I also need to convert the Hz from 60Hz to 50Hz.
I have found plenty of affordable voltage converters for $100-$300. I'm having a devil of a time finding a Hz converter for this machine. They can install an aggregate conversion on the machine but that will add 3 months of production time to my order which I can't afford.
I've found Hz converters for around $2000 which is more than I can spend. Does anyone have any suggestions?
Here are the machine specs:
230V / 50Hz / 1.5KW
Hydraulic Unit:
Q = 2.5 I / min
1370 U / min
Hydraulic cylinder
2 piston Φ 85mm
Stroke about 20mm
Maximum pressure at 320 bar 36.32 t
Production run: about 10 seconds
Thanks in advance for your assistance. Apologies up front, I know nothing about electricity, am deathly afraid of it, and this group appear to be the best suited to help me with this problem.
Regards,
Mike
230V / 50Hz / 1.5KW
Hydraulic Unit:
Q = 2.5 I / min
1370 U / min
Hydraulic cylinder
2 piston Φ 85mm
Stroke about 20mm
Regards,
Mike
