[SOLVED] VHDL Programming Help
arve9066
process(rst, adcclock_80Mhz)
  begin
     if rst = '1' then
        ADC_Timelog <= (others => '0');
		  ADC_Timecnt <= 0;
	  elsif adcclock_80Mhz'event and adcclock_80Mhz = '1' then
			ADC_Timecnt <= ADC_Timecnt + 1;
			time_ack <= '0';
			if(ADC_Timecnt = 8192) then
				ADC_Timelog <= ADC_Timelog + '1';
				Timestamp <= "11" & "000" & calibration & ADC_Timelog;
				time_ack <= '1';
				ADC_Timecnt <= 0;
		end if;
	  end if;
  end process;
process(adcclock_80MHz,time_ack)
begin
	if adcclock_80MHZ'event and adcclock_80MHz='1' then
		if time_ack = '1' then
			timelog <= timelog+1;
			if timelog < 64 then
			calibration <='1';
				elsif timelog > 64 then
				calibration <='0';
				elsif timelog > 128 then
				calibration <='1';
				timelog <=0;
			end if;
		end if;
	end if;
end process;
I need to create a signal called calibration that is ON for 64 cycles and OFF for 64 cycles and repeat based on the signal time_ack which is again driven high or low depending on the count of masterclock adcclock_80MHz. The code does not seem to work and the signal calibration always seem to be stuck at 0. I initialize it as 1, so it does the transition to 0 once and then stuck at 0. any idea why?
Never mind. Stupid question. Fixed it myself. :-|
Did you try to simulate the above ?
If you did - please post your testbench code.
If you didn't - start now.
The second process has all of the code in the time_ack = '1' branch. this occurs every 8192 cycles.
You want timelog to increment in the else branch, under certain conditions.
