+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Member level 3
    Points: 1,872, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jul 2009
    Posts
    59
    Points
    1,872
    Level
    10
    4byte data is not flowing between two modules in verilog
    Hello all.
    i am a bit new in verilog... i have in my top module two other modules instatiated, the problem is when i try to send data from counter to uart, on the logic analyzer connected to uart line, i read 00 00 00 00
    The data out/inputs are declared like bellow
    module counter_v2(
                                 output reg [31:0] fdata_out
    module uart4byte(
                               input [31:0] data,
    And in the main module i have the two modules instantiated and tied like bellow,
    I tryied some debuging for the uart with parameter zzz[31:0] = 32'h AABBCCDD and this way it works.
    But if i try to connect data of the uart4bye with the fdata_out its not working. Why?
    wire stream;
     counter_v2 ccc(
     	.fdata_out(stream)
    uart4byte uuu(
      .data(stream),
    •   Alt13th April 2017, 20:06
      advertising
  2. #2
    Super Moderator
    Points: 28,611, Level: 41
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,551
    Points
    28,611
    Level
    41
    Re: 4byte data is not flowing between two modules in verilog
    Why are you using a single bit
    wire stream;
    to represent a 32-bit connection from fdata_out to data?
