Results 1 to 13 of 13
    Points: 465, Level: 4
    Jul 2016
    41
    465
    20x4 OLED 4 bit initilization
    Hi all,
    i need assembly or C language coding for 4bit-20x4 OLED display and initialization comparison of OLED and LCD display.
    Thanks...
    •   Alt13th April 2017, 11:49
      advertising
    Banned
    Points: 5,417, Level: 17
    Jun 2016
    1,159
    5,417
    17
    Re: 20x4 OLED 4 bit initilization
    Post the datasheet of your OLED Display which shows the initialization scheme.
    Advanced Member level 1
    Points: 5,380, Level: 17
    Aug 2008
    Islamabad, Pakistan
    439
    5,380
    17
    If your OLED has the same controller as in LCD, then initialization will be the same.
    Otherwise read its datasheet as Okada suggested.
    Jul 2016
    41
    465
    NHD-0420DZW-AY5.pdfi have attached the datasheet
    Quote Originally Posted by Okada View Post
    Points: 49,008, Level: 54
    Most Frequent Poster
    Apr 2014
    10,045
    49,008
    54
    page#19 shows what to do.
    Where do you see the problem?
    Banned
    Jun 2016
    1,159
    5,417
    17
    Here I have provided a code earlier.
    http://www.edaboard.com/showthread.p...light=NewHaven
    •   Alt13th April 2017, 13:07
      advertising
  7. #7
    Jul 2016
    41
    465
    Here i added my code for OLED initilization...
    but my OLED is not ON
    ; Subroutine Name	: init_lcd
    ; Purpose			: Initialise LCD for 4 Bit Communication
    ; Input				: Nil
    ; Output			: Nil
    init_lcd:
    ;function set:
    				ldi   temp, 15
    				rcall com_wt						; wait for 15ms after power on reset
    				ldi   temp, 0b00000011				;
    				rcall lcd_out
    ;function set:
    				ldi   temp ,5
    				rcall com_wt
    				rcall lcd_out
    ;function set
    				rcall delay_micros
    				rcall delay_micros
    				ldi   temp,0b00000011
    				rcall lcd_out
    				ldi   temp,5
    				rcall com_wt
    ;function set for  4 bit mode 2lines and 5x7 font size
    				ldi   temp,0b00000010
    				rcall lcd_out
    				rcall delay_micros
    				ldi   temp,0x28;0b00001100
    				rcall com_out;lcd_out
    				ldi   temp,2
    				rcall com_wt
    ;cursor/display shift: shift the cursor position to right
    				ldi   temp , 0b00010100
    				rcall com_out
    				rcall delay_micros
    ;display on/off mode
    				ldi   temp , 0b00001100
    				rcall com_out
    				rcall delay_micros
    ;entry mode
    				ldi   temp , 0b00000110
    				rcall com_out
    				rcall delay_micros
    ;clr display
    				ldi   temp , 0b00000001
    				rcall com_out
    				ldi   temp , 2
    				rcall com_wt
    				ret
    ; Subroutine Name	: com_out
    ; Purpose			: To send command word to LCD by 4 bit communication
    ; Input				: temp (Register)
    ; Output			: Nil
    ; Registers Used	: temp, temp1
    com_out:
    				push  temp
    				swap  temp
    				andi  temp,0b00001111
    				ori   temp,0b00000000
    				rcall lcd_out
    				pop   temp
    				ori   temp,0b00000000
    				rcall lcd_out
    				rcall	delay_micros
    				ret
    ; Subroutine Name	: lcd_out
    ; Purpose			: To send 1 Byte data to LCD by 4 bit commmunication
    ; Output			: Nil
    lcd_out:
    				in    temp1,portc
    				andi  temp1,0b11000000
    				or    temp,temp1
    				out   portc,temp
    				sbi   portc,lcd_en
    				nop
    				cbi   portc,lcd_en
    				ret
  8. #8
    Apr 2014
    10,045
    49,008
    54
    What are your exact display to microcontroller port connections?
    What fixed connections?
  9. #9
    Jul 2016
    41
    465
    D4 - PORTC0
    D5 - PORTC1
    D6 - PORTC2
    D7 - PORTC3
    EN - PORTC4
    RS - PORTC5
    and 16x2 lcd is perfectly working for this configuration.
  10. #10
    Apr 2014
    10,045
    49,008
    54
    with the given code you just init the display and clear the display.
    There is no data output.
    So how can you know it is OFF?
    PS: Please give all informations at once, to keep the discussion short. No piece by piece informations.
    •   Alt21st April 2017, 08:56
      advertising
  11. #11
    Jul 2016
    41
    465
    i have written big program with 16x2 lcd display, so i want to change OLED instead of LCD. my queries are, what im going to change in OLED initialization?
  12. #12
    Banned
    Jun 2016
    1,159
    5,417
    17
    If you use my code then nothing to change. Newhaven OLED displays are HD44780 compatible. Only Strobe duration has to be increased.
  13. #13
    Jul 2016
    41
    465
    Thanks, i got..
    but after update values to OLED, if i press RESET button OLED does not start from initialization. its over write to next row.... what to do?
