how we add the TECHNOLOGY file in ASSURA
abhishekece
Newbie level 3
hello sir,
Hi, I am trying to run DRC but in technology option it's not showing my library i.e. cmos45 nm. even I have attached in startup of schematic and schematic is running fine but for layout DRC is not running. It shows in DRC as undefined. no option is there of designated library cmos 45nm I have attached a snap of it.it is showing cmos 90nm library.please send snap with step by step.
I do not understand : thanks to screen capture, it looks like DRC rules are defined, because you have well labelled errors...
Regards,
G
The design library should be have a technology file
attached to it, upon creation or by menu action of
the user.
Assura ought to then pick that up. But have you
thoroughly inspected the setup options to see if
calling out explicitly, is an option?
Library is not technology. You need both paths
(all paths) to be asserted.
Do you not have CAD support folks who make
sure things are set up for the designers?
hello sir,
thanks for the reply but sir it has also 90 nm technology 's drc file. but my need is DRC file of 45nm. i have also attached by CIW Window process( CIW Window>>Technology File manager>>Attach ). but during drc run time i shows option only undefined and 90nm . plrase tell me another process for attach DRC File.
