+ Post New Thread
Results 1 to 15 of 15
  1. #1
    Junior Member level 1
    Points: 122, Level: 1
    Join Date
    Apr 2017
    Posts
    19
    Points
    122
    Level
    Changing the function of logic blocks in Xilinx FPGA
    Is there a way to change the logical function of the elements in FPGA by modifying the libraries or something like that?
    Assume that we have a design that implementation of this design on FPGA contains on or more AND gates. Now we want to do something that this AND, works as an OR gate by not modifying the design. In other words, we want to force FPGA elements to malfunction.
    Is it possible to do such thing?
    Thanks
  2. #2
    Advanced Member level 5
    Points: 18,802, Level: 33
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,602
    Points
    18,802
    Level
    33
    Re: Changing the function of logic blocks in Xilinx FPGA
    What?
    You want to change the function by not changing the function? You want to change the libraries but not have it change your design? You want to force the FPGA to malfunction? You could lower the voltage. You could expose it to radiation.
    This really all doesn't make much sense, at least to me.
  3. #3
    Points: 33,920, Level: 44
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,209
    Points
    33,920
    Level
    44
    The simple answer is yes you could, if you replace one set of your code with another set of your code that is pin compatible. You cannot change the base primitives.
    •   Alt12th April 2017, 18:55
      advertising
  4. #4
    Super Moderator
    Points: 26,817, Level: 39
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,096
    Points
    26,817
    Level
    39
    Quote Originally Posted by TrickyDicky View Post
    If you somehow managed to do so, then the tools would probably not work correctly anymore. As anywhere it needs to implement an AND gate you would end up with an OR gate instead, even in places where you don't want to do that.
    The closest to what you are attempting to do is to write out an EDIF netlist and modify the nestlist to change a cell from one type to another to create your "FPGA malfunction".
    Not sure what you are trying to do here, but it seems like a ridiculous idea.
  5. #5
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,602
    Points
    18,802
    Level
    33
    The whole idea of changing an AND to an OR IS CHANGING THE DESIGN. There are no AND or OR gates in the FPGA, there are LUTs (lookup tables) that implement the logic function.
  6. #6
    Advanced Member level 3
    Points: 4,284, Level: 15
    Join Date
    Feb 2015
    Posts
    706
    Points
    4,284
    Level
    15
    This sounds like partial reconfiguration. Many devices support this, but tool support may be difficult to get.
  7. #7
    Join Date
    Apr 2017
    Posts
    19
    Points
    122
    Level
    Quote Originally Posted by barry View Post
    I know that. That was just an example, I mean that for example a LUT was supposed to provide outputs as AND gate, and now instead of AND output, we want it to generate other outputs, no matter what.
    But, as I said before, we dont want to change the design or any modification before the synthesis process.
    •   Alt13th April 2017, 08:15
      advertising
  8. #8
    Join Date
    Apr 2017
    Posts
    19
    Points
    122
    Level
    What?
    The idea is complicated somehow, but the point is, by lowering the voltage or exposing it to radiation, the malfunction effects will become uncontrollable and I can not observe the changes.
    Quote Originally Posted by ads-ee View Post
    By changing the netlist, you just change what you wanted the FPGA to do. And the FPGA is working just as well as before! by FPGA malfunction, I mean that you loaded the FPGA with X design, but it doesn't works as X.
    Look at the image below:
    Click image for larger version.
    I want to change the behavior of this logic block. But I don't know how. What if I target the flip-flop. Is it possible?
  9. #9
    Super Moderator
    Points: 232,490, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    40,147
    Points
    232,490
    Level
    100
    A tool might give you the option to change LUT vectors or logic cell options and save the changes to the configuration bitstream without synthesizing and fitting the design anew. Don't know if it's possible with recent Xilinx tools.
    Altera Quartus has the Resource Property Editor for this purpose.
    1 members found this post helpful.
  10. #10
    Join Date
    Apr 2017
    Posts
    19
    Points
    122
    Level
    Quote Originally Posted by FvM View Post
    Thanks for your answer dear FvM.
    This Property Editor is something like FPGA Editor provided by Xilinx? You mentioned that this tool is capable of changing logic cell options. Do these options include logical behavior of the cell or only the connection and interconnection changes ?
  11. #11
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    40,147
    Points
    232,490
    Level
    100
    As said, I was talking about the Altera tool, don't know regarding Xilinx. LUT vector defines the logic function, it can e.g. flip AND to OR.
    In practice, there are very little applications for this kind of engineering change in regular design flow. What I did, is e.g. modifying PLL phase shifts or output driver parameters without recompilation.
    •   Alt13th April 2017, 11:49
      advertising
  12. #12
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,602
    Points
    18,802
    Level
    33
    Xilinx used to have FPGA Editor (I don't know if they still have it). It would allow you to go in and change routing and, I believe, LUT functions and then generate a bit file. But I still have no idea why you would want to do this.
  13. #13
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,096
    Points
    26,817
    Level
    39
    Vivado has an editor and you can modify the LUT and write out a bitstream if you so desire. Though I really don't understand why they want to do this.
  14. #14
    Join Date
    Apr 2017
    Posts
    19
    Points
    122
    Level
    Its kind of testing the design against unwanted condition in working situation.
  15. #15
    Join Date
    Apr 2017
    Posts
    19
    Points
    122
    Level
    You mean modifying the generated bitstream before downloading to FPGA? If so, does it need to be re-synthesized?
