[SOLVED] how to use Xval() function in PSS simulation
kadikaram
Junior Member level 3
how to use xval() funtion in pss simulation
Hi, I want to use the Xval() function in PSS simulation, because i sweep the input power (dbm). can anybody help to use that function...!
Re: how to use xval() funtion in pss simulation
Describe your situation correctly.
You don't describe anything.
Just use like below function, it gives the x value of your graph.
xval(vh('pss"/net5"'(1)))
here net5 is input net.
You don't describe tool name which you use.
Show us followings.
(1) Correct simulator name
(2) Correct post processing tool name
