+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Junior Member level 1
    Points: 1,293, Level: 8
    Join Date
    Jan 2011
    Posts
    15
    Points
    1,293
    Level
    8
    How to test different values of generic (generic map) in vhdl all in one testbench -
    Hi
    VHDL-I was wondering how to test different values/conditions of generics (generic map) all in one testbench without making multiple testbenches with different generic conditions...
    Thanks a lot
  2. #2
    Super Moderator
    Points: 27,821, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,355
    Points
    27,821
    Level
    40
    Re: How to test different values of generic (generic map) in vhdl all in one testben
    How about a package file that has a bunch of constant declarations that you use for the generic map constants you assign.
    •   Alt12th April 2017, 00:07
      advertising
  3. #3
    Advanced Member level 3
    Points: 4,827, Level: 16
    Join Date
    Feb 2015
    Posts
    805
    Points
    4,827
    Level
    16
    Your testbenches can also have generics. In modelsim, you can pass generics using -g. This only works for basic types.
    vsim -gANY_NAME_HERE=5
    There are other options as well. For example, within a function in a package you can convert a test case number into a more complex type. I think you can also have functions that read complex test cases from a file as well.
  4. #4
    Advanced Member level 5
    Points: 35,066, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,423
    Points
    35,066
    Level
    45
    You can't change generics during run time, so the only options are to either
    1) run the test bench multiple times using scripting
    2) instantiate the dut multiple times in a single testbench.
    Usually, people use the first method to keep single cases separate and allow easier debugging
  5. #5
    Join Date
    Jan 2011
    Posts
    15
    Points
    1,293
    Level
    8
    Thanks everyone. I was wondering if anyone can share an example here passing on generics with are std_logic_vectors. Also then how to use assert statements then as it will be different for different generic parameters.
    •   Alt12th April 2017, 11:10
      advertising
  6. #6
    Join Date
    Jan 2011
    Posts
    15
    Points
    1,293
    Level
    8
    I tried passing it but it didn't work for me. A working example will be appreciated.Thanks
  7. #7
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,423
    Points
    35,066
    Level
    45
    An example would be rather simple as ant generics are possible. Are you asking for code examples or scripting examples?
    It may me easier if you post the code that isn't working so we can see why.
  8. #8
    Join Date
    Jan 2011
    Posts
    15
    Points
    1,293
    Level
    8
    Quote Originally Posted by TrickyDicky View Post
    Both would be nice.Thanks very much
  9. #9
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,423
    Points
    35,066
    Level
    45
    For generics
    Code VHDL - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    Library IEEE;
    Use IEEE.std_logic_1164.all;
    Entity mytest is
      Generic (
        Myslv : std_logic_vector
    End entity mytest;
    Architecture test of mytest is
    Begin
      Inst : entity work.myent
      Generic map (
        Some_generic => myslv
    End architecture;
    Vsim mytest -gmyslv=11001100
  10. #10
    Join Date
    Jan 2011
    Posts
    15
    Points
    1,293
    Level
    8
    For generics
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    Library IEEE;
    Entity mytest is
      Generic (
    End entity mytest;
    Begin
      Generic map (
    End architecture;
    Thanks very much. I did exactly the same but was not able to make it work. Anyway you very also suggesting that one can use the functions to chane the generics many time in a single test bench. Can I have an example for that? Cheers
    •   Alt20th April 2017, 12:10
      advertising
  11. #11
    Points: 5,928, Level: 18
    Achievements:
    7 years registered
    Join Date
    Jul 2010
    Sweden
    Posts
    772
    Points
    5,928
    Level
    18
    Quote Originally Posted by sonika111 View Post
    You must start the simulator once for every combination of generics, but you can supply them from the command line so the design and test bench files can stay unchanged.
