Results 1 to 9 of 9
    Points: 99, Level: 1
    Dec 2016
    7
    99
    [Moved]: to inspect & decap interior surface mounted capacitors
    I'm not an engineer sorry but I wanted to post a question about surface mounted capacitors. Can't figure out which group to put my question.
    Points: 45,895, Level: 52
    Apr 2011
    Minneapolis, Minnesota, USA
    11,453
    45,895
    52
    re: [Moved]: inspecting & recapping interior surface mounted capacitors
    Since you're asking about a physical capacitor package, the present section is suitable (Mechanical Engineering and Design).
    Description on the forum home page:
    "Mechanical engineering issues and different mechanical design techiques for your specific project ex. construction, metal works, cabinets, racks, crates, enclosures, front panels"
    •   Alt8th April 2017, 23:50
      advertising
    Dec 2016
    7
    99
    Quote Originally Posted by BradtheRad View Post
    Thank you. My question is can the capacitors as seen in the following picture be decaped ? Why to inspect the interior or inside.
    •   Alt9th April 2017, 02:01
      advertising
    Full Member level 5
    Points: 1,943, Level: 10
    Aug 2015
    Coral Springs, Florida
    285
    1,943
    10
    No, they cannot be decapped. They are MLCC and their dielectric is ceramic.
    Why do you need to inspect the interior?
    •   Alt9th April 2017, 04:30
      advertising
    Dec 2016
    7
    99
    Quote Originally Posted by SLK001 View Post
    Then how can the interior be inspected for anomalies ? Something that should not be there such as a transceiver, antenna and front end that sort of thing.
    SLK001 so they cannot be decapped can they be broken open with a sharp cutting tool like a utility knife ?
    Full Member level 5
    Aug 2015
    285
    1,943
    10
    Re: [Moved]: inspecting & recapping interior surface mounted capacitors
    Quote Originally Posted by victor6799 View Post
    You can pot them in epoxy and then slowly grind them down to nothing (stopping every 5-10 thousandths of an inch to photograph). Your better approach would be to replace them one-by-one, then test for the anomalies.
    Are you saying that you suspect a miniature transceiver is being placed inside one of your capacitors?
  7. #7
    Dec 2016
    7
    99
    Not in just mine but at the factory.
  8. #8
    Full Member level 5
    Aug 2015
    285
    1,943
    10
    That would take miniaturization to a new level. The largest of these caps is only 0.060" by 0.120".
    •   Alt12th April 2017, 21:24
      advertising
  9. #9
    Points: 11,789, Level: 26
    Feb 2010
    UNITED KINGDOM
    1,880
    11,789
    26
    Re: [Moved]: to inspect & decap interior surface mounted capacitors
    Strange thread, are we talking paranoia here?
