Results 1 to 8 of 8
    Full Member level 3
    Points: 1,449, Level: 8
    Jul 2014
    182
    1,449
    8
    communication with pc fro fpga
    hi,
    i am using a cyclone 5 sockit. my design is working fine in fpga and the output is coming to a 46 bit register in fpga at a speed of 200hz.
    is there any way to save these result to my computer?
    In sockit threre is an uart and ethernet. is it possible to store the result to my computer using any of these?
    i just want a simple way to store the result..is there any other way which will be a simple one?
    any help one topic is really appreciated.
    regards
    •   Alt8th April 2017, 08:40
      advertising
    Points: 11,924, Level: 26
    Aug 2011
    2,435
    11,924
    26
    Re: communication with pc fro fpga
    You'll probably need to write a simple PC application that captures the data over the UART.
    Member level 5
    Points: 2,435, Level: 11
    whack's Avatar
    Feb 2006
    81
    2,435
    11
    Write to the serial port and capture the data using a serial terminal. This way you won't have to write any software on PC side. There's lot's of good choices of serial terminals, each having it's strengths and weaknesses. I used to use the on from Br@y++ a lot:
    https://sites.google.com/site/terminalbpp/
    •   Alt8th April 2017, 13:44
      advertising
    Full Member level 3
    Jul 2014
    182
    1,449
    8
    hi,
    is there any software available for this? that i can download and install in my pc
    and what about rs 232 protocol for this?
    i dont even have any idea where to start :(
    regards
    Full Member level 3
    Jul 2014
    182
    1,449
    8
    Quote Originally Posted by shaiko View Post
    hi,
    can you please give a little more information about this ?
    thanks and regards
    Advanced Member level 3
    Points: 6,703, Level: 19
    7 years registered Created Blog entry
    dpaul's Avatar
    Jan 2008
    Germay
    967
    6,703
    19
    Blog Entries
    A bit different reply...
    If you can make TeraTerm recognize the serial port then data coming in from FPGA to PC can be displayed in the TeraTerm console. It is then possible to manually save the data to a file from the console.
    .....yes, I do this for fun!
    •   Alt24th April 2017, 09:12
      advertising
  7. #7
    Full Member level 3
    Jul 2014
    182
    1,449
    8
    hi
    i decided to use an uart to usb port in my fpga(serial port). for that i decided to use an uart rs232 quartus ip in my design.
    but there is a 31 bit input and output register in ip. so i got few doubts in that. i didnt got any demo program using rs 232 ip. so anybody got a demo program or some information about how to give input to 32 bit register (else how to use it)please share it .it will be very helpful for me
    i am using embedded command shell in my pc....
    thanks
  8. #8
    Full Member level 3
    Jul 2014
    182
    1,449
    8
    hi,
    // rs232_uart.v
    // Generated using ACDS version 16.0 211
    `timescale 1 ps / 1 ps
    module rs232_uart (
    input wire address, // avalon_rs232_slave.address
    input wire chipselect, // .chipselect
    input wire [3:0] byteenable, // .byteenable
    input wire read, // .read
    input wire write, // .write
    input wire [31:0] writedata, // .writedata
    output wire [31:0] readdata, // .readdata
    input wire clk, // clk.clk
    input wire UART_RXD, // external_interface.RXD
    output wire UART_TXD, // .TXD
    output wire irq, // interrupt.irq
    input wire reset // reset.reset
    rs232_uart_rs232_0 rs232_0 (
    .clk (clk), // clk.clk
    .reset (reset), // reset.reset
    .address (address), // avalon_rs232_slave.address
    .chipselect (chipselect), // .chipselect
    .byteenable (byteenable), // .byteenable
    .read (read), // .read
    .write (write), // .write
    .writedata (writedata), // .writedata
    .readdata (readdata), // .readdata
    .irq (irq), // interrupt.irq
    .UART_RXD (UART_RXD), // external_interface.export
    .UART_TXD (UART_TXD) // .export
    endmodule
    above one is rs 232 uart module, did any have any user manual or know how to use it?
    i didnt find any user manual for this, so i dont know what is the values for those control registers .
    is there anything iam missing here.. for transferring my values to pc ??
    can anybody help me on this ?
    thanks and regards
