How to declare C arbitrary-precision types in HLS_For 30 Factorial
Saras015
Banned
A factorial(30) will require at least a 108-bit output. Since C has no native types this large, i have to use the HLS arbitrary-precision types.
So, i started using that data type in my code. But it showing Type "uint64" can not resolved. Please suggest me why this error. How i need to declare in the HLS CODE
Source Code in HLS
Code C - [expand]
8
9
10
11
12
13
14
15
#include <stdio.h>
#define NUM 10
int Factorial(int a[NUM])
#pragma HLS INTERFACE s_axilite port=a bundle=a
#pragma HLS INTERFACE s_axilite port=return bundle=a
int i;
long long int fact=1;
for (i=1; i<=NUM; i++)
#pragma HLS PIPELINE
fact = fact*i;
return fact;
Why don't you show the code using arbitrary precisions integer? It's expected to include ap_cint.h
Thanks for your reply. Sorry, the following codes only i have executed in HLS. Please find the screen shot.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
#include <stdio.h>
#include <stdint.h>
#include "ap_cint.h"
#define NUM 30
int i;
uint64 fact=1;////
Fact_data(a[NUM]);
fact = fact*i;
return 0;
ERROR DURING SIMULATIOM
Compiling(apcc) ../../../../fact_test.c in debug mode
@I [HLS-10] Running 'c:/Xilinx_2015_4/Vivado_HLS/2015.4/bin/unwrapped/win64.o/apcc.exe'
            for user 'Optics2015A' on host 'optics2015a-pc' (Windows NT_amd64 version 6.1) on Thu Apr 06 12:02:40 +0530 2017
            in directory 'E:/Saraswathy/Factorial_Task/Factorialprj/solution1/csim/build'
../../../../fact_test.c:19:19: warning: data argument not used by format string [-Wformat-extra-args]
 printf("\nllu\n",fact);
1 warning generated.
@I [APCC-3] Tmp directory is apcc_db
@I [APCC-1] APCC is done.
   Compiling(apcc) ../../../../fact.c in debug mode
            for user 'Optics2015A' on host 'optics2015a-pc' (Windows NT_amd64 version 6.1) on Thu Apr 06 12:03:24 +0530 2017
   Generating csim.exe
obj/fact_test.o: In function `main':
E:\Saraswathy\Factorial_Task\Factorialprj\solution1\csim\build/apcc_db/fact_test.c:177: undefined reference to `Fact_data'
obj/fact.o: In function `Factorial':
E:\Saraswathy\Factorial_Task\Factorialprj\solution1\csim\build/apcc_db/fact.c:183: undefined reference to `Fact_data'
collect2: ld returned 1 exit status
make: *** [csim.exe] Error 1
@E [SIM-1] 'csim_design' failed: compilation error(s).
