Circuit Designing Help? (how many regulator IC's needed)
nick703
Advanced Member level 1
surat
Hello Friends I want to design 5 - axis Stepper motor Driver using Pic Microcontroller of PIC32mx795f512l. In this design I have use power supply 24V DC 3A and 5V Dc 2.5A SMPS.
So My PIC32 genrate 5 pin For Pulse and 5 Pin for Dir of 3.3v Logic for 5 Stepper motor Driver.
Now i use PC817 for isolation and hcf40106 for buffer output . Now i have to use AM26C31 IC for line driver and output i get PULSE+ AND PULSE- same as a dir.
So My question is can i use 1 7805 regulator for all 5 am26c31 power supply or i use 5 7805 ic for am26c31.
please help me to correct design.
AM26C31 IC need less power, it required maximum 100uA, but 7805 having 1A @5V. So there is no loading problems you can connect 5 AM26C31 IC
That's only quiescent current, dynamic current has to be added and particularly output current with line termination (if any). Single 7805 should still work.
I´m confused.
You say you have a 5V 2.5A SMPS.
So, why do you use the 7805?
Klaus
I think the OP want to isolate the drive stuff from the PIC! There is an opto mentioned.
ok so is it possible my current draw in opto coupler?
because when i use single 7805 for all line drive that time working some time and suddenly stop output of pulse.
but when i remove 26c31 that and check pulse and dir. working perfect.
