please help me out with this ERROR(ORPSIM-16047): Must be V
mmkabir
I am using orcad pspice 16.6 full version and trying to implement the macro model of memristor. i am using this code to run
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
.SUBCKT memristor 1 2 6
Eres 1 9 POLY(2)
+(8, 0) (11, 0) 0 0 0 0 1
Vsense 9 4 DC 0V
Fcopy 0 8 Vsense 1
Rstep 8 0 1K
Rser 2 4 10
Fmem 6 0 POLY(2) Vsense
+Ecopy -0.5E-10 0 1E-10 0 -1 0 0 0 1
Cmem 6 0 90nF
Rsp 6 0 1000Meg
Ecopy 7 0 0 6 1
Rc 7 0 1
Ecpy2 10 0 6 0 1
Vref ref 0 DC 1V
R1 10 11 100K
Ssat1 11 0 0 11 SWX
Ssat2 11 ref 11 ref SWX
.MODEL SWX SW(Ron=0.001, Roff=1000Meg,
+Vt=0.00001V, Vh=0.00001V)
.ENDS
when i try to run the net list it shows this message
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
X_M1.Rser OUTPUT X_M1.4 10
X_M1.Fmem STATE 0 POLY 2 X_M1.Vsense Ecopy
+ -0.5E-10 0 1E-10 0 -1 0 0 0 1
X_M1.Cmem STATE 0 90nF
X_M1.Rsp STATE 0 1000Meg
X_M1.Ecopy X_M1.7 0 0 STATE 1
X_M1.Rc X_M1.7 0 1
X_M1.Ecpy2 X_M1.10 0 STATE 0 1
X_M1.Vref X_M1.ref 0 DC 1V
X_M1.R1 X_M1.10 X_M1.11 100K
X_M1.Ssat1 X_M1.11 0 0 X_M1.11 X_M1.SWX
X_M1.Ssat2 X_M1.11 X_M1.ref X_M1.11 X_M1.ref X_M1.SWX
.MODEL X_M1.SWX SW
ERROR -- Invalid model type
Please show me the path to solve this problem.
this is the design environment
I am using orcad 16.6 full version to implement the macromodel of memristor and using this spcie code
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
Eres 1 9 POLY(2)
Vsense 9 4 DC 0V
Fcopy 0 8 Vsense 1
Rstep 8 0 1K
Rser 2 4 10
Cmem 6 0 90nF
Rsp 6 0 1000Meg
Ecopy 7 0 0 6 1
Rc 7 0 1
Ecpy2 10 0 6 0 1
Vref ref 0 DC 1V
R1 10 11 100K
Ssat1 11 0 0 11 SWX
.ENDS
Whenever i try to run the simulation it shows me this message
Code dot - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
**** 03/26/17 10:22:18 ***** PSpice 16.6.0 (October 2012) ***** ID# 0 ********
 ** Profile: "SCHEMATIC1-sim1"  [ D:\CADENCE\simulations\macromodel simu1-PSpiceFiles\SCHEMATIC1\sim1.sim ]
 ****     CIRCUIT DESCRIPTION
** Creating circuit file "sim1.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
* From [PSPICE NETLIST] section of D:\SPB_Data\cdssetup\OrCAD_PSpice/16.6.0/PSpice.ini file:
.lib "D:\Cadence\SPB_16.6\tools\pspice\library\memristor macro Model.lib"
.lib "nom.lib"
*Analysis directives:
.TRAN  0 100m 0 1u
.OPTIONS ADVCONV
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source MACROMODEL SIMU1
X_M1         INPUT OUTPUT STATE MEMRISTOR
R_R1         OUTPUT 0  1k TC=0,0
R_R2         N00216 STATE  1G TC=0,0
V_V1         INPUT 0
+SIN 0 1Vdc 500Hz 0 0 0
V_V2         N00216 0 0.5Vdc
**** RESUMING sim1.cir ****
.END
**** EXPANSION OF SUBCIRCUIT X_M1 ****
X_M1.Eres INPUT X_M1.9 POLY 2 X_M1.8 0 X_M1.11 0 0 0 0 0 1
X_M1.Vsense X_M1.9 X_M1.4 DC 0V
X_M1.Fcopy 0 X_M1.8 X_M1.Vsense 1
X_M1.Rstep X_M1.8 0 1K
X_M1.Rc X_M1.7 0 1
.MODEL X_M1.SWX SW
How to solve this problem please help me
This should work
r1 1 0 1
R2 2 0 1
X1 1 2 0 memristor
Eres 1 9 POLY(2)
Vsense 9 4 DC 0V
Fcopy 0 8 Vsense 1
Rstep 8 0 1K
Rser 2 4 10
+VEcopy -0.5E-10 0 1E-10 0 -1 0 0 0 1
Cmem 6 0 90nF
Rsp 6 0 1000Meg
VEcopy 7 0 0 ;6 1
Rc 7 0 1
Ecpy2 10 0 6 0 1
Vref ref 0 DC 1V
R1 10 11 100K
Ssat1 11 0 0 11 SWX
.MODEL SWX VSWITCH (Ron=0.001, Roff=1000Meg,
.ENDS
.op
.end
Changes - Switch Model in PSpice is VSWITCH, it is not SW.
Second problem is with F device "Fmem" - here you can use a E device as controlling source. The change above is convert E device to V - however you need to make sure model intent is not altered. Change above does not gurantee that
Thank you very much for your reply. I need one more and last help. I am also getting error in the following code aswell. Please can you help me out with this.
.SUBCKT memristor plus minus PARAMS:
+ Ron=100 Roff=16K Rinit=11K D=10N uv=10F p=10
Gx 0 x value={I(Emem)*uv*Ron/D^2*f(V(x),p)}
Cx x 0 1 IC={(Roff-Rinit)/(Roff-Ron)}
Raux x 0 1T
Emem plus aux value={-I(Emem)*V(x)*(Roff-Ron)}
Roff aux minus {Roff}
Eflux flux 0 value={SDT(V(plus,minus))}
Echarge charge 0 value={SDT(I(Emem))}
.func f(x,p)={1-(2*x-1)^(2*p)}
*;.func f(x,i,p)={1-(x-stp(-i))^(2*p)}
.ENDS
