+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Junior Member level 3
    Points: 292, Level: 3
    Join Date
    Jun 2016
    Posts
    30
    Points
    292
    Level
    Synopsys DC power report meaning
    Hi.
    I made a small module and got post-synthesis reports including timing, area, power etc.
    In power report, is it show that average power dissipation including switching activity??
  2. #2
    Full Member level 4
    Points: 1,381, Level: 8
    Join Date
    Oct 2015
    Posts
    219
    Points
    1,381
    Level
    8
    Re: Synopsys DC power report meaning
    Power report from DC should have Total Dynamic Power ( switching power ) and Cell Leakage Power ( Static ) separately.
    To improve one's brain, the doors are needed over the keys.
    •   Alt21st March 2017, 04:56
      advertising
  3. #3
    Join Date
    Jun 2016
    Posts
    30
    Points
    292
    Level
    Quote Originally Posted by slutarius View Post
    Is "switching power" considering switching activity??
  4. #4
    Full Member level 4
    Join Date
    Oct 2015
    Posts
    219
    Points
    1,381
    Level
    8
    Yes, DC uses its internal approach to estimate the switching activities in case you did not provide it.
    For accurate report, the back-annotation load and switching activities should be provided.
    •   Alt21st March 2017, 05:15
      advertising
  5. #5
    Join Date
    Jun 2016
    Posts
    30
    Points
    292
    Level
    You help me a lot!!
    Thanks!
  6. #6
    Full Member level 4
    Join Date
    Oct 2015
    Posts
    219
    Points
    1,381
    Level
    8
    You also can check the command "set_switching_activity" to know how to configure switching parameter.
  7. #7
    Join Date
    Jun 2016
    Posts
    30
    Points
    292
    Level
    I have a one more question.
    In power report using DC, this report shows average(or some middle range value) power consumption?? not worst case??
  8. #8
    Points: 5,363, Level: 17
    Join Date
    Apr 2016
    Posts
    1,126
    Points
    5,363
    Level
    17
    Quote Originally Posted by minho_ha View Post
    Worst case, real worst case analysis, would require dynamic power analysis with simulation data to drive the inputs accordingly.
    Really, I am not Sam.
    •   Alt21st March 2017, 20:21
      advertising
  9. #9
    Full Member level 4
    Join Date
    Oct 2015
    Posts
    219
    Points
    1,381
    Level
    8
    The corner should be worst case.
    The "average" means the way/method that power consumption is calculated on that corner.
    They are different terms.
