+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 3
    Points: 607, Level: 5
    Join Date
    Jan 2014
    NM
    Posts
    Points
    607
    Level
    Can I have a large L in amplifier design?
    Hi All,
    If I am going to design an op amp, with a tiny current to get low power consumption design, the calculated w/l would be very small, can I use like 1um/40um for w/l? will there be some drawbacks?
    I saw some threads that is saying that we can use a large L for designing large resistor, but I am not sure if I can use it as a transistor.
    Thanks so much!
    •   Alt20th March 2017, 22:29
      advertising
  2. #2
    Advanced Member level 5
    Points: 25,954, Level: 39
    Join Date
    Nov 2001
    Earth
    Posts
    3,666
    Points
    25,954
    Level
    39
    Re: Can I have a large L in amplifier design?
    Is it too small W/L ratio ?? There should be DFM rules from point of foundry process.
    •   Alt21st March 2017, 00:16
      advertising
  3. #3
    Newbie level 1
    Points: 408, Level: 4
    Join Date
    Jan 2015
    Posts
    Points
    408
    Level
    How about using stacked device?
    TSMC 40nm, max length is only 10um.
