+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Member level 1
    Points: 555, Level: 5
    Join Date
    Feb 2015
    Posts
    33
    Points
    555
    Level
    Timing Corners for setup check
    What corner is used for setup check?
    Process - Slow
    Temp - high
    Voltage - high
    This PVT condition makes cell delays as large as possible. Is this used for setup check to make setup check more critical.
    •   Alt20th March 2017, 21:19
      advertising
  2. #2
    Points: 5,363, Level: 17
    Join Date
    Apr 2016
    Posts
    1,126
    Points
    5,363
    Level
    17
    Re: Timing Corners for setup check
    Quote Originally Posted by identical View Post
    Process - Slow
    Temp - high
    Voltage - high
    First and foremost, read the documentation that comes with the PDK. There are some nuances that are hard to capture with broad statements like "process = slow". There is also temperature inversion corners that are not intuitive.
    Generally speaking, your worst setup corner is process slow, temperature high, voltage low.
