low current bridge rectifier
jjamwal
Newbie level 6
USA
Hi all,
I am looking for a smd bridge rectifier that can convert mill volts from magnetic inductance a convert to DC without much loss.
Please suggest a part number that sees fit.
A bridge rectifier suffers at least two diode drops so you won't find one for just a few mV. The best you will manage is four Schottky signal diodes (BAT85 for example). With very small signals you either have to amplify them first or use a "precision rectifier" circuit using an op-amp.
