+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 2
    Points: 650, Level: 5
    Join Date
    Feb 2017
    Posts
    122
    Points
    650
    Level
    can I do custom design using a standard cell library only ?
    Hello all,
    If I have a standard cell library, can I use it to make a custom design out of these cells in Virtuoso/Custom Designer or I need the PDK ?
    or generally, if I want to do either vlsi or custom design using the only standard cells...why would I need a PDK ?
    Thanks
    •   Alt20th March 2017, 19:52
      advertising
  2. #2
    Points: 5,363, Level: 17
    Join Date
    Apr 2016
    Posts
    1,126
    Points
    5,363
    Level
    17
    Re: can I do custom design using a standard cell library only ?
    I don't think you understand what a PDK is.
    •   Alt20th March 2017, 23:08
      advertising
  3. #3
    Full Member level 2
    Join Date
    Feb 2017
    Posts
    122
    Points
    650
    Level
    Quote Originally Posted by ThisIsNotSam View Post
    Thank you for your respectful comment....What I understand about PDK is that it contains technology data, the base devices, DRC and LVS decks, model files. However, the standard cell library already has symbol view, hspice model and gds for each cell. so if my intention is to do a custom circuit with these std cells, would I need to have the PDK ?
    •   Alt21st March 2017, 13:18
      advertising
  4. #4
    Join Date
    Apr 2016
    Posts
    1,126
    Points
    5,363
    Level
    17
    Please tell me how you are even going to start virtuoso without a PDK.
    Spice models are useless if you don't have the transistors models... which are part of the PDK. You won't even haven a layer map, you won't be able to tell what a transistor is just from a GDS.
