+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 5
    Points: 310, Level: 3
    Join Date
    Nov 2015
    Posts
    10
    Points
    310
    Level
    Will this feeding mechanism right/work for 8*1 patch antenna array ?
    I am trying to design a feeding mechanism for 8 patch antenna array.
    I have used 50 ohm transmission lines followed by a 70.71 ohm quarter wave transformers(circular shape). Please see attached image for more clarity. I have made inset feed patches. They have good performance at 2.3 Ghz.
    It will be a great help if you can let me know any fundamental issues in the design or if there is a better way to design feeding for patch array.
    Regards
    •   Alt20th March 2017, 08:19
      advertising
  2. #2
    Advanced Member level 3
    Points: 6,096, Level: 18
    Join Date
    Jun 2012
    Edmonton, Canada
    Posts
    953
    Points
    6,096
    Level
    18
    Re: Will this feeding mechanism right/work for 8*1 patch antenna array ?
    The Wilkinson power divider is a pretty standard architecture. The only comment I have is that you could make it more space efficient with a N-branch power divider, but those are more difficult to make.
    Looks good as is. Good luck with the layout!!
  3. #3
    Newbie level 2
    Points: 1,278, Level: 8
    Join Date
    Apr 2010
    Germany
    Posts
    Points
    1,278
    Level
    8
    It seems fine. The 70 Ohm lines should off course be quarter wavelength at your desired frequency. The 50 Ohm ones though can be made smaller (if you want to).
    •   Alt20th March 2017, 17:42
      advertising
  4. #4
    Newbie level 5
    Join Date
    Nov 2015
    Posts
    10
    Points
    310
    Level
    Update::
    I have run into a problem.
    The distance between center to center of 8 patches have to be same. At the same time, the striplines A&B need to be equal. Somehow, I can't solve both the problems simultaneously. I tried a lot of calculations.
    While calculating distance from patch to patch, I have not considered inset feed length in the total length of patch.
    I guess A & B cannot be unequal. Should I consider inset feed length and then calculate center to center spacing?
    It will be a great help if you can help to resolve the problem.
    Regards
  5. #5
    Super Moderator
    Points: 241,468, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,921
    Points
    241,468
    Level
    100
    I don't see the purpose of Wilkinson power divider for an antenna array. Most designs are using simple power dividers.
  6. #6
    Newbie level 5
    Join Date
    Nov 2015
    Posts
    10
    Points
    310
    Level
    Quote Originally Posted by FvM View Post
    Hey FvM,
    I only know how to design Wilkinson power divider. If you could suggest any material for further study of different power dividers, I can proceed to solve this problem.
    I have a personal aim to make this array work and observe results.
    Regards
  7. #7
    Member level 2
    Points: 451, Level: 4
    Join Date
    Feb 2017
    Posts
    48
    Points
    451
    Level
    You don't have to do all the lines straight you can calculate the striplines according to furthest patch antenna and then come back to feed from there.
    •   Alt24th March 2017, 10:48
      advertising
  8. #8
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,921
    Points
    241,468
    Level
    100
    Simple power divider can be e.g. made of 70 ohm quarter wave lines without the s23/s32 enhancing resistor.
    You also have the option to use 1:4 dividers made of 100 ohm lines instead of 1:2 dividers, as already mentioned in post #2.
