+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Newbie level 5
    Points: 118, Level: 1
    Join Date
    Dec 2016
    Posts
    8
    Points
    118
    Level
    Microcontroller Based firing angle control of Pic Microcontroller
    Hello everyone.I am doing my project Microcontroller based firing angle control of Scr .for this i am using Analog input 0-5volt ,a ZCD as interrupt ..but i am unable to do programming plz help anyone ..i know the logic but i am not able to write the code ..plz help me
    •   Alt19th March 2017, 23:28
      advertising
  2. #2
    Advanced Member level 5
    Points: 19,990, Level: 34
    barry's Avatar
    Join Date
    Mar 2005
    California, USA
    Posts
    3,852
    Points
    19,990
    Level
    34
    Re: Microcontroller Based firing angle control of Pic Microcontroller
    Key phrase here: "I am doing my project..."
    Translation: "please do my project for me".
    •   Alt20th March 2017, 01:28
      advertising
  3. #3
    Super Moderator
    Points: 54,942, Level: 57
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,117
    Points
    54,942
    Level
    57
    I'm not writing code.
    But you will find people to help you to write your own code.
    SCR control.
    How is your SCR gate control hardware?
    Isolating, or not? If isolating: how? Transformer, optical...?
    Do you need pulse trains?
    One or two SCRs?
    What is the load? Purely resistive, capacitive, inductive.
    (In worst case a transformer, which is very critical on trigger unsymmetries, causing DC voltage)
    What frequency?
    What smallest delay, what biggest delay?
    Do you want to build a true regulation, or just a angle control?
    Where does your setpoint come from?
    In either case.
    * you need to detect zero cross. In both directions.
    * then you need to start a trigger delay
    * generate the firing signal
    * switch off the firing signal
    * wait for the next zero cross.
    Because it is a timing critical application ..i'd use hardware periferal. Capture, (PWM) signal generation, timer/counter, ISR.
    This all depends on your used hardware. Therefore you should give us the informatiins.
    But I (we) don't want to work through complete datasheets, therefore you should do this.
    Best is if you could give all necessary information at once, not piece by piece.
    Klaus
    •   Alt20th March 2017, 07:15
      advertising
  4. #4
    Newbie level 5
    Join Date
    Dec 2016
    Posts
    8
    Points
    118
    Level
    Hello sir ,i am usin 4 SCR in bridge configuration.and i have to use both resistive as well as inductive load.
    i am using zero crossing detector to create the firing pulse and applied it to interrupt.i am using pic16f877a ic.
    to vary the firing pulse i am using a variable pot of 0-5 volts which is applied to analog port.and according to which the firing ange is varied.i tried to do the programming part but i am unable to do it.i made the simulation on proteus 7.sir i need to varying pulse at the output of pic 1should vary during positive half cycle and another should vary in another half cycle.in my simulation i am gettin only 1 pulse.so i need code which can fire 4 SCR simultaneously.if possible help me.
    Last edited by andre_teprom; 20th March 2017 at 21:08. Reason: Merged 2 posts: 1 containing only attachments, other containing text
  5. #5
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    Join Date
    Apr 2014
    Posts
    11,117
    Points
    54,942
    Level
    57
    you just show some foreign files.
    But you should show what you have done so far. And what your ideas are.
    (Maybe itīs in the .DSN files, but I canīt open it)
    --> You need to show your schematic and you need to show at least your flow chart. And if you have done some coding, the show it, too.
    Klaus
    •   Alt21st March 2017, 10:21
      advertising
  6. #6
    Super Moderator
    Points: 25,547, Level: 38
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,687
    Points
    25,547
    Level
    38
    Blog Entries
    ...and considering that this file extension isn't supported anymore by the most recent Proteus releases, it gives the strong impression that it is not his own project.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
