+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Newbie level 3
    Points: 39, Level: 1
    Join Date
    Mar 2017
    Posts
    Points
    39
    Level
    how to write a verilog code using point form??
    parameter RED =3'b000; //if assume as 0 round off ~ 0
    parameter YELLOW =3'b001; //if assume as 1.2 round off ~1
    parameter GREEN =3'b010; //if assume as 2.1 round off ~ 2
    parameter BLUE =3'b011; //if assume as 1.7 round off ~ 2
    parameter COKLAT =3'b100; //if assume as 0.2 round off ~ 0
    parameter BLACK =3'b101; //if assume as 1.4 round off ~ 1
    parameter PURPLE =3'b110; //if assume as 2.4 round off ~ 2
    parameter ORANGE =3'b111; //if assume as 0.8 round off ~ 1
    i want to make coding which i represent the parameter of 3 bit to a point form integer. after that i want to make a condition if the assume is given then it will trigger to the round off number...
    exmple : if i want 3 bit (001) which i assume to be 1.2 will be 1 as output....???plz help me with this coding....??
    •   Alt17th March 2017, 08:38
      advertising
  2. #2
    Full Member level 3
    Points: 1,543, Level: 8
    Join Date
    Jul 2014
    Posts
    189
    Points
    1,543
    Level
    8
    Re: how to write a verilog code using point form??
    Quote Originally Posted by yeppolife92 View Post
    hi,
    so basically you need to round your fixed point fractional number to an integer right?
    how you represent the fractional number (eg: 1.2) in binary form ?
    what is fractional width and integer width ?
    how you are giving input to the design ?
    regards
  3. #3
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    yeppolife92,
    It appears you don't know how fixed point values are represented in binary.
    The fixed point numbers are made up of sums of powers of 2.
    e.g.
    Q2.5 would be an 8-bit signed fixed point number with the value in decimal calculated by the following
    -s*2**2 + m[1]*2**1 + m[0]*2**0 + f[4]*2**-1 + f[3]*2**-1 + f[2]*2**-1 + f[1]*2**-1 + f[0]*2**-1
    or..
    -s*4 + m[1]*2 + m[0] + f[4]*0.5 + f[3]*0.25 + f[2]*0.125 + f[1]*0.0625 + f[0]*0.03125
    therefore if you have a number like 010.11001 that would become:
    -0*4 + 1*2 + 0 + 1*0.5 + 1*0.25 + 0*0.125 + 0*0.0625 + 1*0.03125 = 2.78125
    With your number descriptions of 0-2.4 the best you can achieve with 3-bits is numbers like: 0, 0.5, 1.0, 1.5, etc. as you can only represent fx2.3 (2 magnitude bits with 1 fractional bit...3-bits total) so the magnitude can be 0-3 and the fraction is either 0 or .5.
    If the factional part is 1 then round up otherwise truncate.
    •   Alt17th March 2017, 16:06
      advertising
  4. #4
    Newbie level 3
    Join Date
    Mar 2017
    Posts
    Points
    39
    Level
    im sorry bro...i still cant get it? i still dont know how to write coding in this case..
  5. #5
    Newbie level 3
    Join Date
    Mar 2017
    Posts
    Points
    39
    Level
    how to write a code in point form part 2
    hye gaizz,
    //below is the coding that i have done..the above description is the question i ask for upgrading the coding below..can u help me?
    [syntax=verilog]module decoder(
    input wire CLK,
    input wire RESET,
    output reg[2:0]A,
    output[6:0]state,
    output reg[6:0]count
    reg[6:0]decoder_state;
    reg[6:0]step;
    //output declaration
    //state
    parameter S0=7'b0000000,
    S1 =7'b0000001,
    S2 =7'b0000011,
    S3 =7'b0000111,
    S4 =7'b0001111,
    S5 =7'b0011111,
    S6 =7'b0111111,
    S7 =7'b1111111,
    S8 =7'b1111110,
    S9 =7'b1111100,
    S10 =7'b1111000,
    S11 =7'b1110000,
    S12 =7'b1100000,
    S13 =7'b1000000,
    S14 =7'b0000000,
    S15 =7'b0001000,
    S16 =7'b0011000,
    S17 =7'b0001110,
    S18 =7'b0111100,
    S19 =7'b0111110,
    S20 =7'b1110111,
    S21 =7'b1111111,
    S22 =7'b1011111,
    S23 =7'b1001111,
    S24 =7'b0011110,
    S25 =7'b0011100,
    S26 =7'b0001100,
    S27 =7'b0010000,
    S28 =7'b0000000;
    //COUNT
    parameter SEC13 =7'b0001101;
    parameter SEC7 =7'b0000111;
    assign state=decoder_state;
    always@(posedge CLK or posedge RESET)
    begin
    if(RESET==1)
    begin
    decoder_state<=S0;
    count<=0;
    end
    else
    case(step)
    0: if(count<SEC13)
    begin
    step<=0;
    decoder_state<=S0;
    count<=count+1'b1;
    end
    else
    begin
    step<=1;
    decoder_state<=S1;
    count<=0;
    end
    1: if(count<SEC7)
    begin
    step<=1;
    decoder_state<=S1;
    count<=count+1'b1;
    end
    else
    begin
    step<=2;
    decoder_state<=S2;
    count<=0;
    end
    2: if(count<SEC7)
    begin
    step<=2;
    decoder_state<=S2;
    count<=count+1'b1;
    end
    else
    begin
    step<=3;
    decoder_state<=S3;
    count<=0;
    end
    3: if(count<SEC7)
    begin
    step<=3;
    decoder_state<=S3;
    count<=count+1'b1;
    end
    else
    begin
    step<=4;
    decoder_state<=S4;
    count<=0;
    end
    4: if(count<SEC7)
    begin
    step<=4;
    decoder_state<=S4;
    count<=count+1'b1;
    end
    else
    begin
    step<=5;
    decoder_state<=S5;
    count<=0;
    end
    5: if(count<SEC7)
    begin
    step<=5;
    decoder_state<=S5;
    count<=count+1'b1;
    end
    else
    begin
    step<=6;
    decoder_state<=S6;
    count<=0;
    end
    6: if(count<SEC7)
    begin
    step<=6;
    decoder_state<=S6;
    count<=count+1'b1;
    end
    else
    begin
    step<=7;
    decoder_state<=S7;
    count<=0;
    end
    7: if(count<SEC13)
    begin
    step<=7;
    decoder_state<=S7;
    count<=count+1'b1;
    end
    else
    begin
    step<=8;
    decoder_state<=S8;
    count<=0;
    end
    8: if(count<SEC7)
    begin
    step<=8;
    decoder_state<=S8;
    count<=count+1'b1;
    end
    else
    begin
    step<=9;
    decoder_state<=S9;
    count<=0;
    end
    9: if(count<SEC7)
    begin
    step<=9;
    decoder_state<=S9;
    count<=count+1'b1;
    end
    else
    begin
    step<=10;
    decoder_state<=S10;
    count<=0;
    end
    10: if(count<SEC7)
    begin
    step<=10;
    decoder_state<=S10;
    count<=count+1'b1;
    end
    else
    begin
    step<=11;
    decoder_state<=S11;
    count<=0;
    end
    11: if(count<SEC7)
    begin
    step<=11;
    decoder_state<=S11;
    count<=count+1'b1;
    end
    else
    begin
    step<=12;
    decoder_state<=S12;
    count<=0;
    end
    12: if(count<SEC7)
    begin
    step<=12;
    decoder_state<=S12;
    count<=count+1'b1;
    end
    else
    begin
    step<=13;
    decoder_state<=S13;
    count<=0;
    end
    13: if(count<SEC7)
    begin
    step<=13;
    decoder_state<=S13;
    count<=count+1'b1;
    end
    else
    begin
    step<=14;
    decoder_state<=S14;
    count<=0;
    end
    14: if(count<SEC13)
    begin
    step<=14;
    decoder_state<=S14;
    count<=count+1'b1;
    end
    else
    begin
    step<=15;
    decoder_state<=S15;
    count<=0;
    end
    15: if(count<SEC7)
    begin
    step<=15;
    decoder_state<=S15;
    count<=count+1'b1;
    end
    else
    begin
    step<=16;
    decoder_state<=S16;
    count<=0;
    end
    16: if(count<SEC7)
    begin
    step<=16;
    decoder_state<=S16;
    count<=count+1'b1;
    end
    else
    begin
    step<=17;
    decoder_state<=S17;
    count<=0;
    end
    17: if(count<SEC7)
    begin
    step<=17;
    decoder_state<=S17;
    count<=count+1'b1;
    end
    else
    begin
    step<=18;
    decoder_state<=S18;
    count<=0;
    end
    18: if(count<SEC7)
    begin
    step<=18;
    decoder_state<=S18;
    count<=count+1'b1;
    end
    else
    begin
    step<=19;
    decoder_state<=S19;
    count<=0;
    end
    19: if(count<SEC7)
    begin
    step<=19;
    decoder_state<=S19;
    count<=count+1'b1;
    end
    else
    begin
    step<=20;
    decoder_state<=S20;
    count<=0;
    end
    20: if(count<SEC7)
    begin
    step<=20;
    decoder_state<=S20;
    count<=count+1'b1;
    end
    else
    begin
    step<=21;
    decoder_state<=S21;
    count<=0;
    end
    21: if(count<SEC13)
    begin
    step<=21;
    decoder_state<=S21;
    count<=count+1'b1;
    end
    else
    begin
    step<=22;
    decoder_state<=S22;
    count<=0;
    end
    22: if(count<SEC7)
    begin
    step<=22;
    decoder_state<=S22;
    count<=count+1'b1;
    end
    else
    begin
    step<=23;
    decoder_state<=S23;
    count<=0;
    end
    23: if(count<SEC7)
    begin
    step<=23;
    decoder_state<=S23;
    count<=count+1'b1;
    end
    else
    begin
    step<=24;
    decoder_state<=S24;
    count<=0;
    end
    24: if(count<SEC7)
    begin
    step<=24;
    decoder_state<=S24;
    count<=count+1'b1;
    end
    else
    begin
    step<=25;
    decoder_state<=S25;
    count<=0;
    end
    25: if(count<SEC7)
    begin
    step<=25;
    decoder_state<=S25;
    count<=count+1'b1;
    end
    else
    begin
    step<=26;
    decoder_state<=S26;
    count<=0;
    end
    26: if(count<SEC7)
    begin
    step<=26;
    decoder_state<=S26;
    count<=count+1'b1;
    end
    else
    begin
    step<=27;
    decoder_state<=S27;
    count<=0;
    end
    27: if(count<SEC7)
    begin
    step<=27;
    decoder_state<=S27;
    count<=count+1'b1;
    end
    else
    begin
    step<=28;
    decoder_state<=S28;
    count<=0;
    end
    28: if(count<SEC13)
    begin
    step<=28;
    decoder_state<=S28;
    count<=count+1'b1;
    end
    else
    begin
    decoder_state<=S0;
    count<=0;
    end
    default: decoder_state<=S0;
    endcase
    end
    always@(*)
    begin
    case(decoder_state)
    S0: begin
    A=RED;
    end
    S1: begin
    A=YELLOW;
    end
    S2: begin
    A=GREEN;
    end
    S3: begin
    A=BLUE;
    end
    S4: begin
    A=COKLAT;
    end
    S5: begin
    A=BLACK;
    end
    S6: begin
    A=PURPLE;
    end
    S7: begin
    A=ORANGE;
    end
    S8: begin
    A=PURPLE;
    end
    S9: begin
    A=BLACK;
    end
    S10: begin
    A=COKLAT;
    end
    S11: begin
    A=BLUE;
    end
    S12: begin
    A=GREEN;
    end
    S13: begin
    A=YELLOW;
    end
    S14: begin
    A=RED;
    end
    S15: begin
    A=YELLOW;
    end
    S16: begin
    A=GREEN;
    end
    S17: begin
    A=BLUE;
    end
    S18: begin
    A=COKLAT;
    end
    S19: begin
    A=BLACK;
    end
    S20: begin
    A=PURPLE;
    end
    S21: begin
    A=ORANGE;
    end
    S22: begin
    A=PURPLE;
    end
    S23: begin
    A=BLACK;
    end
    S24: begin
    A=COKLAT;
    end
    S25: begin
    A=BLUE;
    end
    S26: begin
    A=GREEN;
    end
    S27: begin
    A=YELLOW;
    end
    S28: begin
    A=RED;
    end
    default: begin
    A=RED;
    end
    endcase
    end
    endmodule[/syntax]
    Click image for larger version.
ID:	137127Click image for larger version.
ID:	137128Click image for larger version.
    Last edited by BradtheRad; 20th March 2017 at 03:40. Reason: Added formatted window
  6. #6
    Newbie level 3
    Join Date
    Mar 2017
    Posts
    Points
    39
    Level
    yup..and i want the coding of that..
    •   Alt20th March 2017, 03:16
      advertising
  7. #7
    Full Member level 3
    Join Date
    Jul 2014
    Posts
    189
    Points
    1,543
    Level
    8
    hi ,
    i assume you didnt done tthe coding for this::
    based on above statements max value is 2.4 . so if you take an 8 bit binary ( two bit for integer & 6 bit for fraction)
    10.011001 = 2.390625 ( 2^1*1+2^0*0 . 0*2^-1+1*2^-2+1*2^-3...)
    == 2+0 . (0+.25+.125+0+0.015625)=2.390625
    so with a 3 bit binary, max you can achieve is .5 accuracy . (01.1)=(2.5)
    please check ads-ee replay above . he explain this better . i think if you get some clarity on how to represent a fractional number you can easily solve this.
    because in your coding you need to decide how many integer & fractional width you need to use based on your requirements :)
    its based on you for 2.4 ,either you need to use 8 bit 10.011001 = 2.390625 or 16bit 10.01100110011001=2.39996337890625
    so please decide the fixed and integer width ( i am taking here 8 bit )
    01.101100 =1.6875 thats max you can achieve using 8 width.
    01.100000 = 1.5
    x = 8'b01101100;
    if ( 8'b01100000 < x) begin
    y<= 3'b010;
    end else begin
    y <= 3'b001;
    end
    regards
  8. #8
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    3-bits cannot represent numbers like 1.7 etc.
    all possible numbers in a fx2.3 (positive only - 2 integer and 3 total bits, i.e. 2 integer and 1 fractional bit) representation:
    001 - 0.5
    010 - 1.0
    011 - 1.5
    100 - 2.0
    101 - 2.5
    110 - 3.0
    111 - 3.5
    as you can see the bit width of 3 is limiting the values you can represent. So you will have to increase the bit width of the fractional part of your values, as dipin mentioned, or settle with the above fixed point numbers.
    Instead of trying to make these numbers from this list be fractional values I suggest you just make them a look up table.
    [syntax=verilog]reg [1:0] round_off;
    case (color)
    RED : round_off <= 0;
    YELLOW : round_off <= 1;
    GREEN : round_off <= 2;
    BLUE : round_off <= 2;
    COKLAT : round_off <= 0;
    BLACK : round_off <= 1;
    PURPLE : round_off <= 2;
    ORANGE : round_off <= 1;
    endcase[/syntax]
    Seems a lot easier this way to me, than trying to fit this non-linear arrangement of values into integers.
    I really think you should step back and look at the overall problem and the solution, I don't think you understand what you are doing at this point. Don't you have some sort of experienced mentor that can assist you with ideas of how to approach whatever it is you are attempting to do?
    FYI: edaboard isn't a suitable substitution for a university instructor or an experienced mentor.
