+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Member level 1
    Points: 274, Level: 3
    Join Date
    Nov 2016
    Posts
    34
    Points
    274
    Level
    SPI EEPROM and GPS Receiver
    I have a question, I am intending to configure my GPS the LEA-M8T from my PC. However, after the first configuration, I want the device to be completely standalone.
    The controller for the board which I will design will be the MAX10. I am intending to store the configuration in EEPROM.
    I am considering 2 possibilities:
    1. Is it possible that I connect the MAX10 to EEPROM using SPI or I2C and then the configuration will be transmitted through MAX10 to my GPS again?
    2. Or is it easier to have a SPI based EEPROM and use multiple slave in which the LEA-M8T and the EEPROM work as the slave and my MAX10 works as the master?
    Thank you.
    Best regards,
    RH
    •   Alt10th March 2017, 10:33
      advertising
  2. #2
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    Re: SPI EEPROM and GPS Receiver
    It depends on your requirements.
    My personal preference is to not share the SPI (it's only pins/wires at most) and have each controlled separately one SPI for the LEA-M8T and one for the EEPROM (i.e. the MAX10 has two masters and a bridge between the two).
    If you add a UART or another SPI you can add that to the bridge/arbiter and be able to in-circuit reprogram the EEPROM and LEA-M8T configuration after it's built.
