+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Advanced Member level 5
    Points: 12,223, Level: 26
    Join Date
    Aug 2011
    Posts
    2,484
    Points
    12,223
    Level
    26
    Failing Timequest path not shown in RTL viewer
    Hello,
    I'm using a 128 to 32 bit FIFO in my Altera Cyclone V SOC design.
    Timequest shows a setup violation on 10 lines internal to this IP.
    The "Launch Clock" and "Latch Clock" for the failing paths are the same.
    However, for some reason I can't locate the failing paths in the RTL viewer.
    As if they don't really exist...
    What's going on?
    •   Alt9th March 2017, 10:49
      advertising
  2. #2
    Points: 35,441, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Re: Failing Timequest path not shown in RTL viewer
    They may not exist in the RTL viewer.
    Try the technology map view.
    1 members found this post helpful.
    •   Alt9th March 2017, 11:12
      advertising
  3. #3
    Join Date
    Aug 2011
    Posts
    2,484
    Points
    12,223
    Level
    26
    It's not there either...
    •   Alt13th March 2017, 16:23
      advertising
  4. #4
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    Start looking for blah, blah, blah, removed due to x, y, z begin static type stuff in the reports.
    Or if you really want whatever it is to stick around start adding keep and preserve attributes to those signals.
    Opps, I just noticed you aren't looking for paths you already know exist but are trying to find one that magically appears.
    What does this path look like, can you find it in a netlist of the design?
  5. #5
    Join Date
    Aug 2011
    Posts
    2,484
    Points
    12,223
    Level
    26
    Correct.
    It's an ALTERA IP - a ratio changing (128 to 32 bits) FIFO.
    The failing net is of a RAM block this FIFO uses.
    Good idea, I'll look.
    I suspect these are nets that have been optimized away - yet remain in TimeQuest due to a bug.
