+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 5
    Points: 1,903, Level: 10
    Join Date
    Jan 2014
    Posts
    250
    Points
    1,903
    Level
    10
    Mul18x18 Xilinx primitive + modelsim simu
    Hi guys!!
    I am wondering why I got xxxxx at the output of this primitive when I try to simulate with modelsim. I don't get any error in the compilation and it looks it is going to work well. However I got always the xxx at the output....
    Notice: with the ise simulator I got the same result.....
    Any idea?
    Greetings
    •   Alt8th March 2017, 19:33
      advertising
  2. #2
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    Re: Mul18x18 Xilinx primitive + modelsim simu
    Extremely hard to say what is going on without your code.
    X's usually mean you didn't reset or initialize something or didn't connect some important input signal or if it is pipelined didn't run for long enough to flush out the garbage.
    1 members found this post helpful.
    •   Alt8th March 2017, 19:45
      advertising
  3. #3
    Full Member level 5
    Join Date
    Jan 2014
    Posts
    250
    Points
    1,903
    Level
    10
    Hi!
    I have already solved my problem. I did not declare the MULT component in the right way....
    Thanks a lot.
