FMC104 and VCU118 Compatibility
sahar8j
Newbie level 2
Does anyone know if FMC104 daughter board is compatible with xilinx VCU118 evaluation board?
It probably is. But you should check the schematics of both boards to be sure.
I have checked the signaling of two boards. Both use Vita 57.1 FMC. They were same. Is it enough before buying?
