+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 2
    Points: 31, Level: 1
    Join Date
    Mar 2017
    Posts
    Points
    31
    Level
    FMC104 and VCU118 Compatibility
    Does anyone know if FMC104 daughter board is compatible with xilinx VCU118 evaluation board?
    •   Alt8th March 2017, 13:02
      advertising
  2. #2
    Advanced Member level 5
    Points: 12,223, Level: 26
    Join Date
    Aug 2011
    Posts
    2,484
    Points
    12,223
    Level
    26
    Re: FMC104 and VCU118 Compatibility
    It probably is. But you should check the schematics of both boards to be sure.
    •   Alt8th March 2017, 22:14
      advertising
  3. #3
    Newbie level 2
    Join Date
    Mar 2017
    Posts
    Points
    31
    Level
    I have checked the signaling of two boards. Both use Vita 57.1 FMC. They were same. Is it enough before buying?
