+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Advanced Member level 5
    Points: 12,223, Level: 26
    Join Date
    Aug 2011
    Posts
    2,484
    Points
    12,223
    Level
    26
    Native VHDL negation function
    Hello,
    Does VHDL have a native 2's complement negation function for signed vectors ?
    I.E - a function that takes a signed vector, flips it and adds '1' to the LSB ?
    •   Alt8th March 2017, 12:30
      advertising
  2. #2
    Points: 35,441, Level: 45
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Re: Native VHDL negation function
    yes:
    a <= -b;
    1 members found this post helpful.
  3. #3
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    Quote Originally Posted by TrickyDicky View Post
    yes:
    a <= -b;
    I'm guessing the types for a and b should be signed from numeric_std?
  4. #4
    Advanced Member level 3
    Points: 5,529, Level: 17
    Join Date
    Dec 2015
    Madrid, Spain
    Posts
    994
    Points
    5,529
    Level
    17
    Quote Originally Posted by ads-ee View Post
    I know that you might think of std_logic_signed, std_logic_arith, but no one should use them, instead, the standard.
    -- Id: A.2
    function "-" (ARG: SIGNED) return SIGNED;
    -- Result subtype: SIGNED(ARG'LENGTH-1 downto 0).
    -- Result: Returns the value of the unary minus operation on a
    -- SIGNED vector ARG.
    •   Alt8th March 2017, 22:39
      advertising
  5. #5
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Yes - any standard signed type will work:
    integer
    real
    And from VHDL 2008
    sfixed
    std_logic_vector (when using numeric_std_signed)
    bit_vector (when using numeric_bit_signed)
  6. #6
    Super Moderator
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    integer
    real
    If my understanding is correct, real isn't synthesizable, and integer isn't really a good fit if you want to synthesize something with a fixed bit with that is less than or more than the definition of integer (usually 32-bits in most implementations) and will require extra conversions to make it the correct size. I suppose you can specify a range, but then I always have to mentally convert the range to number of bits in the vector.
    And from VHDL 2008
    sfixed
    I sort of knew about sfixed, but the numeric_std_signed and _bit_signed seem to be addressing the non-IEEE standard package std_logic_signed? I find this very interesting. So is using these packages to allow the use of std_logic_vector (e.g. like a std_logic_vector slice) as part of a signed calculation? That would be convenient and would require less conversions.
  7. #7
    Points: 4,949, Level: 16
    Join Date
    Feb 2015
    Posts
    825
    Points
    4,949
    Level
    16
    I don't think real has an explicit definition in VHDL in terms of binary representation.
    I'll also note that you can import only numeric_std_signed."-" or std_logic_signed."-" . This is advisable as using the entire package changes "=" . For std_logic_1164, comparing different widths for equality would generate an easy to find warning "result always false". For numeric_std_signed, they would each be treated as signed numbers and compared in that manner. "11" = "111".
    IMO, this is a big reason why std_logic_unsigned still exists. It makes VHDL more like Verilog, especially if you include conv_integer from std_logic_arith. (this is "to_integer" in numeric_std_unsigned). I still don't advocate using all of either due to the changes to "=", and because I feel there is value in using signed/unsigned type when there is ambiguity in the operation.
  8. #8
    Achievements:
    7 years registered
    Join Date
    Jun 2010
    Posts
    6,486
    Points
    35,441
    Level
    45
    Quote Originally Posted by vGoodtimes View Post
    I think you mean - IMO, you SHOULD only import numeric_std_signed or std_logic_signed. This is only an opinion, and I doubt anyone will really follow it - importing the whole package is just easier. Also, with a lack of decent VHDL 2008 until rather recently, you're unlikely to see any coding standards mention numeric_std_signed/unsigned at all - most will advocate using numeric_std.
    std_logic_1164 does not define any "=" functions. "=" is declared implicitly for all types in the language. Otherwise you would get a conflict when you imported std_logic_unsigned or numeric_std_signed etc and you would have to chose which one to use explicitly (as you kind of alluded to).
    @ads-ee : I wasnt really talking in terms of synthesis, I was just listing all standard types where the function "-" function is defined.
    •   Alt9th March 2017, 08:33
      advertising
  9. #9
    Join Date
    Feb 2015
    Posts
    825
    Points
    4,949
    Level
    16
    I think we agree, but am not sure. My opinion is that the smallest, easily understood subset of _signed/_unsigned/etc... be used in a design. This is "+" from either signed/unsigned, "-" from signed, and to_integer from unsigned or conv_integer from std_logic_arith (or if you hate the non-ieee of the package, "to_int" from your own package.)
    "-" from _signed is to add the unary operator.
    This gives convenience without redefining a useful property of "=", nor making ambiguous inequalities or multiplications seem like a good idea.
