+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 2
    Points: 233, Level: 2
    Join Date
    Feb 2017
    Posts
    24
    Points
    233
    Level
    module instantiation
    Hello,I have written code for s27 benchmark circuit and counter,I have given output of counter to s27 circuit.When I run the view RTL schematic its showing following error:
    ERROR:Xst:528 - Multi-source in Unit <s27test2> on signal <out<3>>; this signal is connected to multiple drivers.
    Drivers are:
    Primary input port <G3>
    Output signal of FDR instance <str1/d_3>
    how to resolve this?
    I have used instantiation.Below is the code
    module s27test2(G1,G2,G3,G0,clock,reset,out,G17);
    input clock,reset,G1,G2,G3,G0;
    output [3:0]out;
    output G17;
    counter str1 (.clk(clock),.rst(reset),.d(out));
    assign G0=out[0];
    assign G1=out[1];
    assign G2=out[2];
    assign G3=out[3];
    s27 str2(.CK(clock),.g0(G0),.g1(G1),.g2(G2),.g3(G3),.g17(G17));
    endmodule
    •   Alt8th March 2017, 07:05
      advertising
  2. #2
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,598
    Level
    100
    Re: module instantiation
    The problem is in the useless assignments to inputs G0..G3. They can be either input ports or driven by str1 d output. Reconsider!
    •   Alt8th March 2017, 07:17
      advertising
  3. #3
    Join Date
    Feb 2017
    Posts
    24
    Points
    233
    Level
    Yes,I tried that,I want show the inputs G0..G3 in RTL schematic how to do that?
    Click image for larger version.
    •   Alt8th March 2017, 08:45
      advertising
  4. #4
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,598
    Level
    100
    Why not, but that's not related to the problem in post #1. Problem is that G0..G3 can't be inputs of module s27test because they are driven by counter str1.
  5. #5
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,441
    Points
    28,167
    Level
    40
    Quote Originally Posted by ecasha View Post
    May be you should tell us what you need to do, instead of asking about broken code where it is impossible to tell what you wanted to do. (Lack of comments in your code doesn't help).
    16 years later and students are still being taught to use antiquated module port definitions when Verilog 2001 allowed the use of C style port definitions (removes the redundant declarations of port names and then their types).
