+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Newbie level 3
    Points: 36, Level: 1
    Join Date
    Mar 2017
    Posts
    Points
    36
    Level
    Dual Clock Synchronization based Verilog Code
    Hi everyone,
    I am designing an analog system which requires a Verilog code that performs the following.
    Inputs : clk1 (30Mhz) , clk2 (250Khz), reset ( So , the clk1 will complete 120cycles in the time clk2 completes one cycle)
    Output : delay[7:0]
    Problem : The output delay[7:0] should increment only if there is a posedge in both clk1 and clk2.
    Clearer words : it should have a functionality like : always @ ( posedge clk1 && posedge clk2)
    All suggestions welcome. (I'm also paralelly working on it :D)
  2. #2
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
    Re: Dual Clock Synchronization based Verilog Code
    Not implementable in hardware. If clk2 is already synchronized with clk1 and has a pulse duration of one clock period, it can be possibly used as clock enable signal. Otherwise a toggle synchronizer is the best solution
    [syntax=verilog]reg t, t1, t2;
    always @ (posedge clk2) begin
    t <= !t;
    end
    always @ (posedge clk1) begin
    t1 <= t; // Specify false path for this transfer
    t2 <= t1
    if (t1^t2)
    begin
    end
    end[/syntax]
    1 members found this post helpful.
    •   Alt8th March 2017, 06:49
      advertising
  3. #3
    Newbie level 3
    Join Date
    Mar 2017
    Posts
    Points
    36
    Level
    Synthesizable model is not required here. I am going to dump it in an FPGA and use it for the project.
    With respect to your
    I have one solution in mind. Please comment on it.
    Attachment 136750
    •   Alt8th March 2017, 07:00
      advertising
  4. #4
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
    Synthesizable model is not required here. I am going to dump it in an FPGA.
    That's what people call a contradiction in terms. "Dump in FPGA" means synthesis.
    Can't read the attachment, the preview picture suggests unrelated (asynchronous) clocks. Thus a proper synchronization is required to achieve predictable behavior without metastable events. A latch won't do.
    •   Alt8th March 2017, 07:26
      advertising
  5. #5
    Super Moderator
    Points: 28,167, Level: 40
    ads-ee's Avatar
    Join Date
    Sep 2013
    USA
    Posts
    6,440
    Points
    28,167
    Level
    40
    I agree with FvM a latch will likely cause the circuit to fail due to metastable events. It almost seems like you are trying to create a phase detector between two clocks with a large difference in frequencies. Whatever circuit you design to detect (align) the rising edges will likely cause your analog circuit (PLL?) to wander up and down in frequency a lot due to the poor resolution you will end up with. It will almost be required that you hand place the logic so there won't be any surprises when re-implementing the FPGA.
    Maybe you can divide down the 30 MHz (and maybe even the 250KHz) to either 250 KHz or both to 125 KHz (to balance the FF Tco delays), then you can use a simple XOR detector as long as you place the FFs near the last XOR LUT that was placed near the I/O. Doing this divide will require that you start the divide down counters aligned, otherwise you'll likely end up never achieving lock (assuming this is supposed to be part of a phase detector ).
  6. #6
    Points: 5,370, Level: 17
    Join Date
    Apr 2016
    Posts
    1,128
    Points
    5,370
    Level
    17
    Quote Originally Posted by Aravind_Selvaraj View Post
    Oh boy. I don't know where to begin.
  7. #7
    Newbie level 3
    Join Date
    Mar 2017
    Posts
    Points
    36
    Level
    There is an up counter whose clock is clk1(30Mhz). Since we already know that 120*30Mhz = 4uS or 250Khz(clk2). The output of the counter wcould be in phase with the actual clk2(signal).
    Could you suggest a method which triggers the output when either of clk2(250Khz) or counter output (again 250Khz) hits it first. Could this provide a more precise solution?
    •   Alt15th March 2017, 05:56
      advertising
  8. #8
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
    We got two contradicting descriptions, both or unfortunately unclear.
  9. #9
    Newbie level 3
    Join Date
    Mar 2017
    Posts
    Points
    36
    Level
    Sorry for my language. The actual requirement is a trigger signal output which gives out a pulse whenever the posedges of the 2 clocks are very close (i.e. the both the edges occur in a time less than the duration of one period the higher clk (30Mhz)
  10. #10
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,508
    Points
    239,577
    Level
    100
    Can be build using the previously suggested toggle synchronizer. Because clk2 is delayed in the synchronizer, the divided clk1 has to delayed respectively. Increase the acceptance interval to two clock periods to get +/- 33 ns tolerance between clock edges.
