+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 5
    Points: 310, Level: 3
    Join Date
    Nov 2015
    Posts
    10
    Points
    310
    Level
    How to narrow down/change Horizontal Beam Width(HBW) of a Patch Antenna ?
    My patch antenna design:
    Frequency - 2.3 GHZ, ε - 2.64, h - 1.6mm
    Horizontal Beam Width(HBW) - 82.3 degree
    Vertical Beam Width (VBW) - 67 degree
    Observations:
    1. Increasing width leads to decrease in VBW.
    2. No change in HBW with changing length instead it shifts the resonating frequency.
    Now, I want to change my HBW from 82 to 65 degree. It will be a great help if you could tell me the possible ways through which HBW can be changed? I am stuck here from a long time.
    Regards
    •   Alt2nd March 2017, 08:47
      advertising
  2. #2
    Full Member level 3
    Points: 2,267, Level: 11
    Achievements:
    7 years registered
    Join Date
    May 2010
    Vancouver, Canada
    Posts
    186
    Points
    2,267
    Level
    11
    Re: How to narrow down/change Horizontal Beam Width(HBW) of a Patch Antenna ?
    Are you sure it is not another way around? For vertically polarized patch you can change horizontal beam width (the wider the patch the narrower the beamwidth) and can not change vertical beamwidth. To reduce further vertical bemwidth you need to make array of two patches - one on top of another.
    •   Alt8th March 2017, 02:48
      advertising
  3. #3
    Newbie level 5
    Join Date
    Nov 2015
    Posts
    10
    Points
    310
    Level
    Thanks AndreyG!!
    I was looking at my patch in horizontal polarization. It simply solved my problem by rotating patch in 90 degrees. (It was a simple solution) My HBW becomes 67 degree and VBW will be reduced because of vertical array design.
    Can you suggest some reading material for feeding mechanism for 8 vertically polarized patches in vertical array.
