How to see XDC Templates in Vivado 2016.1 ?
msdarvishi
Full Member level 4
Hi all,
Currently, I am using Vivado 2016.1 on Linux. in page 30 of the following User Guide, it is mentioned that the XDC Templates can be launched from the menu Window/Language Templates. Surprisingly, when I follow this menu, I DO NOT SEE the item regarding Language Templates !!! Can anyone knows how can I open the language templates in Vivado?
Link for ug903 (Please see page 30) :
https://www.xilinx.com/support/docu...linx2013_1/ug903-vivado-using-constraints.pdf
Kind replies and helps are in advance appreciated !
Regards,
Why are you looking at a 2013.1 version of the document if you are using 2016.1?
FYI they (Xilinx) sometimes changes things between versions.
