Disk Software for Tektronix PRISM 3001 boot diskette
polegllass
Newbie level 2
I`ve purchased the Tektronix analyzer but I didn`t know the boot diskette is nessesary. I need to make the image of 720 kB boot dikette.
Can enybody help me?
Many thanks,
Pawel
If you're lucky there is a utility that automatically formats a 720k floppy, then writes the boot programs to it.
Or else you'll need to format a 720k floppy with a complicated DOS command in a DOS window. (The command contains number of tracks and sectors.) Then you write system programs to it. This creates a startup diskette. Then add the Tektronix program.
The problem is because I have no software for it.
Visit the Tektronix website, or a Tektronix user forum. They may have specific information.
You need to find out whether you need a computer boot disk, or a boot disk specifically designed for the Tektronix unit.
Many thanks,
Pawel
Hi Pawel,
this is what you are looking for.
also you will likely need other software and manuals for it
look at my imgur links as well
this should give you an idea of what is broadly available, based on what acquision modules are fitted to your 3001
https://imgur.com/a/cQm0m
in regards to does your 3001 have a hard drive read the posts on Tektronix Logic Analyzer Forum as follows
https://forum.tek.com/viewforum.php?f=570
