+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Newbie level 5
    Points: 323, Level: 3
    Join Date
    Feb 2016
    Posts
    10
    Points
    323
    Level
    ESP-01 not responding to AT command
    It's first time for me to use ESP-01 module. I am trying to test new module, using a serial monitor software 'AccessPort' / putty.
    Coming to my point directly, when i reset the module by connecting RST pin to ground, i get following message
    rl.l|.#o lpr2'{'# BoN.$oN #pcd`rlpo $   bn|l lpoN$l onl n{"N l pn rܜ  # o|߄pno d`no l`or'n rlpo rd bn|lrcon l oN $`or' l$`{'o dl`r$N܄No#rono.$"r{l.$"'ܜ   l$l~rd. 'ldlo. . ~ ..no'n2dlc llp#Br$`odd`bl $'oo|o$'# .$  d`rlr"ll {lrpd l`rl.l$`{l{$b#lbr|`"'c" coNn.l$$쎌$ld$d`n.b# lp b $ "p{ls$
    Ai-Thinker Technology Co. Ltd.
    ready
    Here i was expected that getting ready word(Even after garbage) means everything fine. But problem is module is not replying 'OK' on sending 'AT'.
    When i send 'AT' it replies 'ATAT'. Whatever i am sending it, It is replying double word. Means suppose if i send my name 'YOGESH' it is replying 'YOGESHYOGESH'
    Used Baud rate is: 115200, I also tried different baud rates.
    USB to TTL converter CP2120 is used to interfacing with PC
    I don't know, where i am doing wrong? or the module is faulty??
    Last edited by andre_teprom; 17th February 2017 at 21:15. Reason: added QUOTE tags
    •   Alt17th February 2017, 13:35
      advertising
  2. #2
    Points: 10,994, Level: 25
    Kripton2035's Avatar
    Join Date
    Jul 2001
    Western Europe
    Posts
    1,141
    Points
    10,994
    Level
    25
    Re: ESP-01 not responding to AT command
    don't bother with AT commands on an esp8266 : just program it directly with the latest arduino IDE it works better, faster and does not hang out !
    1 members found this post helpful.
    •   Alt17th February 2017, 18:01
      advertising
  3. #3
    Super Moderator
    Points: 25,634, Level: 38
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,712
    Points
    25,634
    Level
    38
    Blog Entries
    The first issue isn't a problem at all. Your text terminal is configured in such a manner that do not recognise non standard ascii characters. The second issue, is due to the fact that the modem is usually configured by manufacturer settings to echoe all received characters. There is a standard Hayes command to disable it. If I remember correctly the proper syntax, just type ATE0.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    •   Alt17th February 2017, 21:19
      advertising
  4. #4
    Newbie level 5
    Join Date
    Feb 2016
    Posts
    10
    Points
    323
    Level
    Thanx for your help.....
    Yes!!!! Now At commands are working fine. I just used the 'terminal' software instead of 'accessport'/'putty'.
    Here CR+LF settings are available easy.........Directly using arduino are also working........
  5. #5
    Super Moderator
    Points: 239,640, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    Did you notice the Putty terminal emulation option settings?
    •   Alt19th February 2017, 12:01
      advertising
  6. #6
    Newbie level 5
    Join Date
    Feb 2016
    Posts
    10
    Points
    323
    Level
    OHHHHHHHH!!!
    Now i noticed these options in putty.....(Not tried yet)
    Thnx, i'll try it.......
  7. #7
    Super Moderator
    Points: 46,856, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,677
    Points
    46,856
    Level
    52
    The manufacturer's name is clear in your startup screen, so that means you're getting something okay. The gibberish characters could be graphics data, perhaps a logo.
