Problem with Altium (some footprints remain off-grid)
kappa_am
Full Member level 6
Vancouver
Hi all,
I have a problem with Altium DXP. I created a PCB project. When I built PCB first time, everything was perfect. Then, I changed the schematics, when I updated the PCB file some component remain unconnected ( not newly added, the components that were in schematic before).
I added new PCB file, in the new file everything is ok. How can I solve this problem? because I have worked a lot on previous PCB file and do not want to loose it.
Regards,
Did you try to reset Unique Id of the problematic components?
It could be a component ID mismatch. If that's the case, the PCB on the component wouldn't be seen as the same on the schematic.
