Apply a Shooting-Newton-PSS/PAC Analysis.I want By changing the input frequency obtain the amplitude and phase of the transfer function of the filter.
Surely see Netlist. All informations are there.1- can you tell me more about Shooting-Newton-PSS/PAC Analysis.i cant find PSS/PAC setting in this link "N path filter " for cadence virtuoso.
It is "analogLib/vsource" not "analogLib/port".2-in this image , input source is defined as port , what is the resistance of port ?
You can not understand simulation at all.if Vin :
a sine wave voltage to the input (Vi) with a frequency of 1 kHz and an amplitude of 0.5 V superimposed on a 0.5 V DC voltage
and switches is NMOS with a square wave voltage with amplitude of 1.2V.
The switching frequency of the switches is 20 kHz.
Vimpulse1 (Vin 0) vsource dc=5 type=dc pacmag=1
Vimpulse1 (Vin 0) vsource dc=5 type=pulse delay=td_in val0=0 val1=1 \
period=1K rise=tr_in fall=tf_in width=tw_in
period=1K rise=tr_in fall=tf_in width=tw_in pacmag=1
I can not know your situation.why my simulink is diffrent with your answers?
Again,how you can calculate FFT for this circuit
and How do you interpret this FFT?
// Generated for: spectre
// Generated on: Apr 23 21:16:27 2001
// Design library name: MyTestLib
// Design cell name: Parallel_SCF
// Design view name: schematic
simulator lang=spectre
global 0
parameters tw_in=1u tw=3u tr_in=0.05u tf_in=0.05u tf=0.05u dv=1e-3 VL=-0.5 \
VH=0.5 tr=0.05u tperiod=12.5u td1=1u k=2 \
td_in=(td1+tr+tw)-(tr_in+tw_in/2) td2=td1+(tperiod-k*(tr+tw+tf))
// Library name: MyTestLib
// Cell name: Parallel_SCF
// View name: schematic
Vimpulse2 (net22 0 Vin 0) vcvs gain=1.0
Vimpulse1 (Vin 0) vsource dc=5 type=dc delay=td_in val0=0 val1=1 period=1K \
R1 (Vct_out net22) resistor r=25K
SW1 (Vin Vmid phi1 0) relay vt1=(VL+VH)/2-(dv) vt2=(VL+VH)/2+(dv) \
ropen=10M rclosed=10m
SW2 (Vmid Vsc_out phi2 0) relay vt1=(VL+VH)/2-(dv) vt2=(VL+VH)/2+(dv) \
Phai_2 (phi2 0) vsource type=pulse val0=VL val1=VH period=tperiod \
delay=td2 rise=tr fall=tf width=tw fundname="Phai_2"
Phai_1 (phi1 0) vsource type=pulse val0=VL val1=VH period=tperiod \
delay=td1 rise=tr fall=tf width=tw fundname="Phai_1"
C2 (Vct_out 0) capacitor c=1n
C6 (Vsc_out 0) capacitor c=1n
C3 (Vmid 0) capacitor c=500.0p
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
digits=5 cols=80 pivrel=1e-3 ckptclock=1800 \
sensfile="../psf/sens.output"
pss pss period=12.5u harms=0 maxacfreq=1M annotate=status
pac pac sweeptype=absolute start=10 stop=40k maxsideband=0
+ annotate=status freqaxis=absout
tran tran stop=4.096m maxstep=0.05u write="spectre.ic" \
writefinal="spectre.fc" annotate=status maxiters=5
save phi1 phi2 Vin Vmid Vsc_out Vct_out
saveOptions options save=selected
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 M1 (VOUT phi2 net08 0) nch w=50u l=130n as=17p ad=17p ps=100.68u \ pd=100.68u sa=340n sb=340n nrd=3.8m nrs=3.8m m=(1)*(1) M0 (net08 phi1 VIN 0) nch w=50u l=130n as=17p ad=17p ps=100.68u pd=100.68u \ sa=340n sb=340n nrd=3.8m nrs=3.8m m=(1)*(1) C2 (net08 0) capacitor c=1p C1 (VOUT 0) capacitor c=60.00f V0 (VIN 0) vsource dc=500.0m type=sine pacmag=1 ampl=500.0m freq=fin vpulse2 (phi2 0) vsource type=pulse val0=1.2 val1=0 period=50u delay=50n \ rise=50n fall=50n width=30u vpulse1 (phi1 0) vsource type=pulse val0=0 val1=1.2 period=50u delay=5u \ rise=50n fall=50n width=20u simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \ tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \ digits=5 cols=80 pivrel=1e-3 sensfile="../psf/sens.output" \ checklimitdest=psf pss pss fund=1K harms=0 errpreset=conservative tstab=200n + maxacfreq=1e6 annotate=status pac pac start=0 stop=1M lin=1000 maxsideband=0 annotate=status modelParameter info what=models where=rawfile element info what=inst where=rawfile outputParameter info what=output where=rawfile designParamVals info what=parameters where=rawfile primitives info what=primitives where=rawfile subckts info what=subckts where=rawfile saveOptions options save=allpub
aho pss fund=20K harms=0
+ errpreset=conservative tstab=200n
+ maxacfreq=200k annotate=status
boke pac start=0 stop=50k lin=1000
+maxsideband=0 annotate=status
