+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Member level 2
    Points: 395, Level: 4
    Join Date
    Feb 2017
    Posts
    47
    Points
    395
    Level
    Coaxial feed of a microstrip antenna
    Hello,I am trying to make a coaxial feed to my circular patch antenna.
    As shown in the photos bellow i have created to metal cilinders one inside the other with dielectric cilinder spacing.
    The dimention are such that the inner pin touches the patch and the outer coating touches the ground plane.
    After ward with boolean operation i made the pin and the patch a single object,the outer coating and the ground a sigle object,
    made a waveguide port and ran the simulation.
    but its not working an showing really low directivity,if you could help me with a step by step manual which i could follow.
    (i have tried to follow both youtube video manuals)
    Thanks.
    Click image for larger version.
ID:	136050Click image for larger version.
ID:	136051Click image for larger version.
ID:	136052Click image for larger version.
    •   Alt11th February 2017, 14:02
      advertising
  2. #2
    Full Member level 3
    Points: 2,267, Level: 11
    Achievements:
    7 years registered
    Join Date
    May 2010
    Vancouver, Canada
    Posts
    186
    Points
    2,267
    Level
    11
    Re: Coaxial feed of a microstrip antenna
    How many mesh cells between top and bottom metals of PCB? Maybe none? Then your connector sees short.
    •   Alt15th February 2017, 01:53
      advertising
  3. #3
    Advanced Member level 5
    Points: 32,294, Level: 43
    Join Date
    Oct 2001
    Posts
    4,623
    Points
    32,294
    Level
    43
    From the posted pictures is hard to understand where the mistake is.
    Try to follow the example below, and you will understand how to design a coaxial feed. Indications might not be exactly the same if you use a different version of the simulator.
    http://www.cc.ntut.edu.tw/~juiching/HFSS%20Probe.pdf
    •   Alt17th February 2017, 13:46
      advertising
  4. #4
    Newbie level 6
    Points: 174, Level: 2
    Join Date
    Jan 2017
    Posts
    11
    Points
    174
    Level
    Hi antenna_beginner, I am a beginner too. I am working on HFSS not CST, but i believe the design should be same even with different softwares. In Coaxial/Probe feeding technique we subtract or remove a circular slot from ground plane and create 3 cylinders(probe, pin, coax) and a circle(waveport) but i am sure about making patch+inner cylinder and ground+outer cylinder as one object each.
ID:	136240 Click image for larger version.
    Follow below clip on youtube to understand better:
    https://youtu.be/ntPqoZ2NI90
  5. #5
    Newbie level 6
    Join Date
    Jan 2017
    Posts
    11
    Points
    174
    Level
    Quote Originally Posted by qurratulayn View Post
    sorry i am *not sure about making patch+inner cylinder and ground+outer cylinder as single object each
    1 members found this post helpful.
    •   Alt18th February 2017, 13:21
      advertising
  6. #6
    Member level 2
    Points: 497, Level: 4
    Join Date
    Aug 2016
    Posts
    45
    Points
    497
    Level
    Dear all,
    please find in this link a tutorial for the coaxial feedline.
    Best regards!
    https://www.youtube.com/watch?v=Md-UeD6iWxs
