KhaledOsmani
Full Member level 6
I intend to make a circuit that records audio from a microphone, and upon switch pressing, the audio is replayed.
I've seen different microcontrollers projects, that uses DAC/PWM and make the job done, but uses too much space/components, and require a sharp code, reasons that I chose a direct audio IC circuit method.
I've searched upon ISD1020A, as well as ISD15100, and found the following complete diagram:
I want to hear comments about fidelity of such circuit, or if there are other more flexible circuits.
My main question is, can I record different audio signals using that circuit, where each audio is triggered by a different pushbutton/switch?
If not, are there any similar circuit that can support more than one record?
The project to build must have nine different audio signals, driven by nine different switches.
Thanks in advance
Thanks in advance
