+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Newbie level 3
    Points: 254, Level: 3
    Join Date
    Oct 2016
    Posts
    Points
    254
    Level
    Fully differential op amp: How to reduce ACM ?
    Hi everyone~
    I've designed a fully differential op amp
    but my common-mode gain is large
    how could I change the parameter to decrease my ACM to -20dB at DC
    Thanks for the reply..
    below is my hspice code
    .subckt  op  vdd  vss  vip  vin  vop  von  vcm  clk
    M1      3      vip      1      vss     n_18     W=20u     L=1.5u   m=80
    M2      4      vin      1      vss     n_18     W=20u     L=1.5u   m=80
    M11     1      vb0     vss     vss     n_18     W=10u     L=1u     m=10
    M3      3      vb1     vdd     vdd     p_18     W=10u     L=1u     m=80
    M4      4      vb1     vdd     vdd     p_18     W=10u     L=1u     m=80
    M5     vop     vb2      3      vdd     p_18     W=20u     L=1u     m=30
    M6     von     vb2      4      vdd     p_18     W=20u     L=1u     m=30
    M7     vop     vb3      5      vss     n_18     W=5u      L=1u     m=20
    M8     von     vb3      6      vss     n_18     W=5u      L=1u     m=20
    M9      5      vb4     vss     vss     n_18     W=20u     L=1u     m=10
    M10     6      vb4     vss     vss     n_18     W=20u     L=1u     m=10
    ***************************CMFB**********************************
    Mcf1   d1      v+      d5      vss     n_18     W=50u     L=0.3u
    Mcf2   vb0     vcm     d5      vss     n_18     W=50u     L=0.3u
    Mcf3   d1      d1      vdd     vdd     p_18     W=50u     L=0.3u
    Mcf4   vb0     d1      vdd     vdd     p_18     W=50u     L=0.3u
    Mcf5   d5      vb5     vss     vss     n_18     W=50u     L=0.3u
    R1     vop     v+      1x
    R2     von     v+      1x
    Click image for larger version.
    Vb1   vb1     vss   1.1v
    Vb2   vb2     vss   0.63v
    Vb3   vb3     vss   1v
    Vb4   vb4     vss   0.53v
    Vb5   vb5     vss   0.6v
    .ends
    x1   vdd   vss   vip   vin   vop    von   vcm   clk   op
    Vdd   vdd    gnd    1.8v
    Vss    vss    gnd    0v
    E+     vip    vcm    7      vss    0.5
    E-      vin    vcm    7      vss   -0.5
    VID     7      vss    DC    0v     ac   1
    VIC    vcm   vss    DC    0.9v
    C1     vop    gnd    4p
    C2     von    gnd    4p
    *.tf v(vop) vid
    .tf v(vop) vic
    Last edited by andre_teprom; 22nd January 2017 at 13:54. Reason: Title related to the subject in question
    •   Alt22nd January 2017, 09:40
      advertising
  2. #2
    Super Moderator
    Points: 241,624, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,945
    Points
    241,624
    Level
    100
    Re: fully differential op amp
    Did you check if all transistors are in saturation?
    Also common mode gain as absolute number isn't significant. You'll either determine ratio of differential to common mode gain, or CMRR with external feedback.
