RSS feed on home page unable to load for a few days.
d123
Advanced Member level 5
Spain
The RSS feed on the left of the homepage (the box above the threads updater/feed), that posts links to related articles, is unable to load and has been so for a few days in the browser I use (Opera), it had always worked fine before.
If in principle everything is up-to-date on my PC (as far as I'm aware and have checked what I thought could be obvious culprits. e.g. Flash Player or Java), what could be causing this problem? The little "loading" circle goes around and around, but doesn't manage to load anything...
Thanks.
Since you mention it, for several days I too have seen a continual loading icon with the message: 'Retrieving RSS feed(s)'. Nothing more appears.
This may be an area where system programmers are revising the interface. Your post is visible to administrators who may have more information to provide.
Hi Brad,
Thanks for replying, it helps to know it's not necessarily to do with something my end; we'll just have to wait for it be sorted out, then.
