+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Junior Member level 3
    Points: 433, Level: 4
    Join Date
    Jul 2016
    Posts
    28
    Points
    433
    Level
    STMicro driver issue
    Hello friends,
    I have a problem and working on it a few days.
    I have L6482H STMicro driver for pumping charge.
    I work with two modes, Pressure and Vacuum.
    When i go to pressure everything work fine, but when i do the vacuum i get THERMAL shutdown.
    When i read the status register i get "11"(device shutdown, pg 58-59 in the datasheet).
    There is no high temperature in the machine and i don't know why it is shutting down itself.
    i will more
    The circuit attached.
    Driver datasheet: http://www.st.com/content/ccc/resour...DM00067131.pdf
    Thanks you all.
    •   Alt11th January 2017, 12:24
      advertising
  2. #2
    Super Moderator
    Points: 241,686, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,965
    Points
    241,686
    Level
    100
    Re: STMicro driver issue
    You should know how you are controlling the stepper motor differently in both modes. We can't.
    A possible reason for device overheating might be an inappropriate high PWM frequency in combination with a high MOSFET gate capacitance.
