Request for hardware test
omidrey
Newbie level 5
Dear All
Good day to you , I have recently prepared one VHDL code for implementing a digital clock and because I don't have any CPLD IC and its programmer , I wonder if any one can test the below code for me and then feedback to me whether the code is correctly working or not
List of Material :
4 seven segments
2 pushbuttons
1 switch
1 cpld / fpga IC
1 oscillator (default is 50 Mhz, obviously if this input clock changes, some change in the code should be taken so that we can have a true and correct 1 hz output to the internal circuits for counting the clock digits. )
Due to uploading limitations, I have changed the type of the file to txt so simply copy and paste content of the txt file in your vhdl synthesizer tool and go on.
I will appreciate if anyone can optimize my code for efficient power consumption and output heating.
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
235
236
237
238
239
240
241
242
243
244
245
246
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity clockticks is Port (
set : in  STD_LOGIC;
clr : in  STD_LOGIC;
clock :in std_logic;
BTN0 : in std_logic; ---Adjust Minutes
BTN1 : in std_logic; ---Adjust Hours
Seg1 : out std_logic_vector (6 downto 0);
Seg2 : out std_logic_vector (6 downto 0);
Seg3 : out std_logic_vector (6 downto 0);
Seg4 : out std_logic_vector (6 downto 0));
end clockticks;
architecture Behavioral of clockticks is
-- Sec, Min, Hr Signals
signal sec : std_logic_vector(5 downto 0);
signal Min1Temp1 : std_logic_vector(3 downto 0);
signal Min10Temp1: std_logic_vector(2 downto 0);
signal Hr1Temp1 : std_logic_vector(3 downto 0);
signal Hr10Temp1 : std_logic_vector(1 downto 0);
signal Min1Temp2 : std_logic_vector(3 downto 0);
signal Min10Temp2: std_logic_vector(2 downto 0);
signal Hr1Temp2 : std_logic_vector(3 downto 0);
signal Hr10Temp2 : std_logic_vector(1 downto 0);
-- Main Outputs which will be used to generate 7segment code
signal Hr1 : std_logic_vector(3 downto 0); -- 1's place
signal Hr10 : std_logic_vector(3 downto 0); -- 10's place
signal Min1 : std_logic_vector(3 downto 0); -- 1's place
signal Min10 : std_logic_vector(3 downto 0); -- 10's place
-- Clock Division signals
signal temporal: STD_LOGIC;
signal counter : integer range 0 to 25000000 := 0; -- Producing 1hz out of 50 Mhz oscillator
signal clk : STD_LOGIC;
begin
-- Producing 1hz clock
process (clr, clock) begin
        if (clr = '1') then
            temporal <= '0';
            counter <= 0;
        elsif rising_edge(clock) then
            if (counter = 25000000) then
                temporal <= NOT(temporal);
                counter <= 0;
            else
                counter <= counter + 1;
            end if;
        end if;
    end process;
clk <= temporal;
--Digital clock in VHDL
process(clr, BTN0, set, clk ) --period of clk is 1 second.BTN0
begin
if clr = '1' then
  Min1Temp1 <= "0000";
  Min10Temp1 <= "000";
 elsif set ='1' and (rising_edge(clk)) then
  if BTN0 = '0' then
   if Min1Temp1 < 9 then
   Min1Temp1 <= Min1Temp1 + 1;
   else
   if Min10Temp1 < 5 then
    Min10Temp1 <= Min10Temp1 + 1;
   else
   end if;
   end if;
  end if;
 end if;
end process;
process(clr, BTN1, set, clk ) --period of clk is 1 second.BTN1
begin
if clr = '1' then
  Hr1Temp1 <= "0000";
  Hr10Temp1 <= "00";
 elsif set ='1' then
  if BTN1 = '0' and (rising_edge(clk)) then
  if Hr1Temp1 < 9   then
   if Hr1Temp1 = 3 and Hr10Temp1 = 2 then
    Hr1temp1 <= "0000";  Hr10Temp1 <= "00";
    else
    Hr1Temp1 <= Hr1Temp1 + 1;
    end if;
   else
    Hr1Temp1 <= "0000";
     if Hr10Temp1 < 2 then
     Hr10Temp1 <= Hr10Temp1 + 1;
     else
     Hr10Temp1 <= "00";
     end if;
    end if;
  end if;
end if;
end process;
process(clk , clr )   -- clock
begin
if clr = '1' then
 sec <= "000000";
 Min1Temp2 <= "0000";
 Min10Temp2 <= "000";
 Hr1Temp2 <= "0000";
 Hr10Temp2 <= "00";
elsif ( BTN0 = '0' or BTN1 = '0') then
 Min1Temp2 <= Min1Temp1;
 Min10Temp2 <= Min10Temp1;
 Hr1Temp2 <= Hr1Temp1;
 Hr10Temp2 <= Hr10Temp1;
else
  if   (clk' event and clk ='1') then
   if sec >= 59    then
   if Min1Temp2 < 9 then
    Min1Temp2 <= Min1Temp2 + 1;
   else
    if Min10Temp2 < 5 then
     Min10Temp2 <= Min10Temp2 + 1;
    else
     if Hr1Temp2 < 9   then
      if Hr1Temp2 = 3 and Hr10Temp2 = 2 then
       Hr1temp2 <= "0000";  Hr10Temp2 <= "00";
      else
       Hr1Temp2 <= Hr1Temp2 + 1;
      end if;
     else
      Hr1Temp2 <= "0000";
      if Hr10Temp2 < 2 then
       Hr10Temp2 <= Hr10Temp2 + 1;
      else
       Hr10Temp2 <= "00";
      end if;
     end if;
    end if;
   end if;
   sec <= "000000";
  else
   sec <= sec + 1;
  end if;
  end if;
end if;
end process;
Min1 <=  Min1Temp1 when (BTN0 = '0') else  Min1Temp2 when (BTN0 = '1');
Min10 <= ('0' & Min10Temp1) when (BTN0 = '0') else  ('0' & Min10Temp2) when (BTN0 = '1');
Hr1  <=  Hr1Temp1 when (BTN1 = '0') else Hr1Temp2 when (BTN1 = '1');
Hr10 <= ("00" & Hr10Temp1) when (BTN1 = '0') else  ("00" & Hr10Temp2) when (BTN1 = '1');
-- Display on segment
process (clk,Min1)
BEGIN
if (clk'event and clk='1') then
case  Min1 is
when "0000"=> Seg1 <="0000001";  -- '0'
when "0001"=> Seg1 <="1001111";  -- '1'
when "0010"=> Seg1 <="0010010";  -- '2'
when "0011"=> Seg1 <="0000110";  -- '3'
when "0100"=> Seg1 <="1001100";  -- '4'
when "0101"=> Seg1 <="0100100";  -- '5'
when "0110"=> Seg1 <="0100000";  -- '6'
when "0111"=> Seg1 <="0001111";  -- '7'
when "1000"=> Seg1 <="0000000";  -- '8'
when "1001"=> Seg1 <="0000100";  -- '9'
 --nothing is displayed when a number more than 9 is given as input.
when others=> Seg1 <="1111111";
end case;
end if;
end process;
process (clk,Min10)
BEGIN
case  Min10 is
when "0000"=> Seg2 <="0000001";  -- '0'
when "0001"=> Seg2 <="1001111";  -- '1'
when "0010"=> Seg2 <="0010010";  -- '2'
when "0011"=> Seg2 <="0000110";  -- '3'
when "0100"=> Seg2 <="1001100";  -- '4'
when "0101"=> Seg2 <="0100100";  -- '5'
 --nothing is displayed when a number more than 5 is given as input.
when others=> Seg2 <="1111111";
end case;
end if;
end process;
process (clk,Hr1)
BEGIN
case  Hr1 is
when "0000"=> Seg3 <="0000001";  -- '0'
when "0001"=> Seg3 <="1001111";  -- '1'
when "0010"=> Seg3 <="0010010";  -- '2'
when "0011"=> Seg3 <="0000110";  -- '3'
when "0100"=> Seg3 <="1001100";  -- '4'
when "0101"=> Seg3 <="0100100";  -- '5'
when "0110"=> Seg3 <="0100000";  -- '6'
when "0111"=> Seg3 <="0001111";  -- '7'
when "1000"=> Seg3 <="0000000";  -- '8'
when "1001"=> Seg3 <="0000100";  -- '9'
when others=> Seg3 <="1111111";
end case;
end if;
end process;
process (clk,Hr10)
BEGIN
case  Hr10 is
when "0000"=> Seg4 <="0000001";  -- '0'
when "0001"=> Seg4 <="1001111";  -- '1'
when "0010"=> Seg4 <="0010010";  -- '2'
 --nothing is displayed when a number more than 2 is given as input.
when others=> Seg4 <="1111111";
end case;
end if;
end process;
end Behavioral;
I am looking forward hearing from you soon .
Best Regards
Omid
you should do a functional simulation to test your code.
... and a timing analysis. Are you sure your code can be implemented in an CPLD (see above)? Consider debouncing your buttons.
why are you setting your temporary signals assynchronously with your buttons?
clk <= temporal;
not a good idea: you are using the signal 'clk' as a clock, but 'temporal' is a register. You should not drive a clock network with logic.
for doing functional test I need to write test bench which I dont know how to do , that's why I requested some one do the hardware test for me.
Why this code cannot be implemented on CPLD? can you explain more? I didn't get what you mean by pointing out my code.
Those buttons are asynchronous so that if any of the buttons pressed then the output become updated when we have the set switch on .
Yes for the clock you are right that we should not drive it with logic , then do you have any solution I can solve it ?
I will appreciate if you have any solutions to your comments so that I can fix it and implement my digital clock.
Regards
Besides what LatticeSemiconductor has mentioned, why are you inconsistent in your use of rising_edge(clk) and (clk'event and clk = '1') for a clock? Use the first the second method considers transitions from Z, X, U, etc => '1' to be valid clock edges, whereas rising_edge(clk) only considers a '0' to '1' transition to be a valid clock edge.
The usual method to deal with clock dividing is to run the logic synchronously with the system clock and create a clock enable pulse that only allows the clocking of FFs at the required period.
I don't think very many CPLDs if any allow for "clock gating" as you've coded below.
This code describes an AND gate in the clock path.
Note, VHDL stands for VHSIC Hardware Description Language, so you should think in terms of what the VHDL describes as hardware, in this case ANDing a signal with the clock implies an AND gate in the clock path.
And invest in the time to learn to write a testbench. I really doubt anyone will be willing to test your code on hardware for free. Everyone who answers questions here are volunteers (i.e. we don't get paid to do this).
How can one write 246 lines of VHDL and not know how to do a test bench ?
Furthermore, in my opinion, you have wrote everything on a single architecture like a C code with many many functions which then needs to write e.g. "the display on segment" code 4 times. I think it would be easier to do, understand, find errors etc if you create components and then instantiate them on the top level. You will then check each component (module which integrates the whole design, which is the top) for errors and will be easier to see if something is not working and where.
Also, you need to add a synchronizer for the asynchronous inputs in order to avoid metastability issues
Dear Sir , thanks for giving me your time to write reply .. in fact I have synthesized this code on ISE 14.7 and it could be successfully synthesized without any error except two warnings related to putting the BTN0 , BTN1 into the sensitivity list of the process function , moreover I have set the XC9500XL in project setting which then after implementing , ISE suggested one of XC9500XL series CPLDs which has 144 pins. Now I dont know if I can trust ISE and transfer this code to the hardware ? Also today I have ordered USB platform programmer for $38 and I plan to buy this XC9500XL CPLD to be able to test my code. what is your suggestion ? Do you think I can get result?
Yes you are right , you do not get paid, but can you do me a favor and write a test bench for me for free as a new year gift? :-D:-D
Dear Cata , thanks for feedback . Indeed I did not write whole of this code , the main core of this code is related to a weblog called vhdldesign hosted on blogspot and I guess it is for indian engineers. However I have modified and added some parts such as clock division and seven segment displays so that I can make the main code close to my aim. I'm not that expert to write testbench , I know the procedures but did not get result. And because I'm under time limitation for delivering this project to the unviersity as final project of the VHDL course , I thought to myself maybe it's better I implement hardware test to get quicker results.
anyhow thanks for your suggestions, by the way can you do me a favor and write a test bench for me or test this code on your FPGA/CPLD?
Regards
No one ever does a hardware implementation without doing functional verification (i.e. simulation of design by a test-bench).
In fact learning to write a test-bench is the only 2nd stage after learning to write RTL.
You seem to be new here. This is not how this forum works. Try out yourself, make mistakes, ask questions, show us what you have done, you'll get all the help. No one will give you the code here.
Instead make a new year resolution and learn how to write a test-bench.
So what, it synthesizes, a steaming pile of feces still stinks even if you spay Fabreze on it. :wink:
You've got multiple experienced working engineers telling you the same thing...write a testbench, but you don't seem to care to learn what they are telling you.
Instead...
Free!? you must be daft.
