+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Junior Member level 3
    Points: 936, Level: 6
    Join Date
    Jan 2013
    Posts
    26
    Points
    936
    Level
    How to extract power profile in Design compiler and SoC encounter
    Dear all,
    I need to feed a sample circuit with a number of random inputs (say for example 1000 input patterns) and then obtain a power trace (power consumed by the circuit during applying the input patterns). As the test circuit may not be small or the number of input patterns may be high, i don't want to use Hspice as it may take a long time. So I want to use Synopsys design compiler or SoC encounter tools to do this. I think such work is possible in both tools but i don't know how to do it. Please some help me. Thanks.
    •   Alt11th January 2017, 10:54
      advertising
  2. #2
    Points: 5,357, Level: 17
    Join Date
    Apr 2016
    Posts
    1,124
    Points
    5,357
    Level
    17
    Re: How to extract power profile in Design compiler and SoC encounter
    do a simulation of the circuit using the inputs you want. then use encounter to do a power estimation. typically you would use a vcd file for this purpose.
    •   Alt11th January 2017, 22:08
      advertising
  3. #3
    Join Date
    Jan 2013
    Posts
    26
    Points
    936
    Level
    Quote Originally Posted by ThisIsNotSam View Post
    Thanks for your reply. I check it.
