+ Post New Thread
Results 1 to 8 of 8
  1. #1
    Full Member level 5
    Points: 2,087, Level: 10
    Join Date
    Nov 2012
    India
    Posts
    266
    Points
    2,087
    Level
    10
    Dual Level converter ICs
    Is there any single IC which contain both the 3.3 to 5 V and 5 to 3.3 V converter. Even some two channels each for both the cases?
    If available pls share me the part number..
    •   Alt11th January 2017, 10:28
      advertising
  2. #2
    Member level 3
    Points: 1,204, Level: 7
    Join Date
    Jun 2013
    Posts
    64
    Points
    1,204
    Level
    7
    Re: Dual Level converter ICs
    1 members found this post helpful.
  3. #3
    Super Moderator
    Points: 57,561, Level: 58
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,713
    Points
    57,561
    Level
    58
    You are asking about two bidirectional signal lines?
    I know the 8 bits wide ICs, don't know if there are two bit wide ICs.
    74lvx3245, or 74lvx4245
    Look at: https://www.fairchildsemi.com/produc...l-translators/
    Ahh, here are 2 bit level converter ICs.
    Klaus
    •   Alt11th January 2017, 23:41
      advertising
  4. #4
    Full Member level 5
    Join Date
    Nov 2012
    India
    Posts
    266
    Points
    2,087
    Level
    10
    Quote Originally Posted by KlausST View Post
    Klaus
    Thanks..
    FXMAR2102 has 2 channels.
    By the way i am interfacing the 3.3V microcontroller with the 5V Max488 IC. Shall i use this isolator for the TX and RX line between them..
    Controller - RX - Channel 1 of FXMAR2102 - DO - Max488
    Controller - TX - Channel 2 of FXMAR2102 - DI - Max488
    Shall i use like this?
  5. #5
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    Join Date
    Apr 2014
    Posts
    11,713
    Points
    57,561
    Level
    58
    Why don't you use MAX3488?
    ...there is no isolator....
    Klaus
    •   Alt12th January 2017, 08:34
      advertising
  6. #6
    Full Member level 5
    Join Date
    Nov 2012
    India
    Posts
    266
    Points
    2,087
    Level
    10
    But if the A,B,X,Y of Max3488 is connected with another device 5V Max488, then will it not be problem?
  7. #7
    Full Member level 5
    Join Date
    Nov 2012
    India
    Posts
    266
    Points
    2,087
    Level
    10
    Click image for larger version.
Name:	MAX488 with MAX3488.jpg
    Shall i connect Two devices like this?? one device is having 5V operating Max 488 and another one is having 3.3 V operating Max3488.
    Will it have any issues on doing it so?
  8. #8
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    Join Date
    Apr 2014
    Posts
    11,713
    Points
    57,561
    Level
    58
    RS485, RS422 are standards. Every device must meet the specifications independent of it's supply voltage.
    If you want detailed information, then reading the datasheets is a good idea:
    MAX3488:
    * -7V to +12V Common-Mode Input Voltage Range
    * Driver Output Voltage (A, B, Y, Z)..........................-7.5V to 12.5V (independent of Vcc)
    * Receiver Input Voltage (A, B) ................................-7.5V to 12.5V (independent of Vcc)
    Klaus
