+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Member level 2
    Points: 1,665, Level: 9
    Achievements:
    7 years registered
    Join Date
    Mar 2009
    Posts
    48
    Points
    1,665
    Level
    9
    LVDS line to drive single ended controls
    I want to use a pair of LVDS line to drive a single ended control line. The control line is used just to enable/disable an IC.
    Enable is when driven above 2V, ideally 3.3 V.
    I understand that LVDS has a current output and also needs a DC termination in this case. I was thinking of parallel termination and have come up with the scheme in the picture. Will this work?
    Click image for larger version.
    Thank you for reading.
    •   Alt10th January 2017, 03:34
      advertising
  2. #2
    Super Moderator
    Points: 55,043, Level: 57
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,137
    Points
    55,043
    Level
    57
    Re: LVDS line to drive single ended controls
    I don't think that LVDS gives reliable voltage levels to drive LVCMOS.
    --> use a single LVDS to LVCMOS receiver. It's just a SOT23-6 package. (If I remember right)
    Klaus
    •   Alt10th January 2017, 07:18
      advertising
  3. #3
    Member level 2
    Achievements:
    7 years registered
    Join Date
    Mar 2009
    Posts
    48
    Points
    1,665
    Level
    9
    Quote Originally Posted by KlausST View Post
    Klaus
    @KlausST: Thanks for the reply.
    I do not fully understand your answer. I believe the reliability of the LVDS lines is limited when the voltages are between + 100 mV (w.r.t. the offset). Is this the same problem that you refer to in your answer. Or do you refer to any other issue?
    I am looking at ICs too. But wanted to implement with a ckt. if possible.
    Thanks again.
    •   Alt10th January 2017, 09:02
      advertising
  4. #4
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    Either use proper LVDS to CMOS conversion - or remove all terminations and probably get sufficient CMOS swing, but also loose LVDS speed.
  5. #5
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    Join Date
    Apr 2014
    Posts
    11,137
    Points
    55,043
    Level
    57
    You need to look at the input threshold specification of what you call "single ended DIO".
    There is a specification for valid low levels (VIL)
    and there is a specification for valid high levels (VIH)
    I doubt your LVDS driver is able to satisfy this specifiaction.
    Klaus
